Working with Multi-dimensional uvm_queue
I’m trying to create an object which is constructed from array of uvm_queue. The idea is that each item in the array is for itself a uvm_queue ( i.e. a list of items).
The problem is I can’t manage to iterate the items of a single ‘memory ID’ list.
When I compile I get the following Error:
*if (ml_mem_array[mem_id][ii].m_addr == a_addr)
xmelab: E,CUVNAA (./utils.sv,47|45): An index has been applied to an inappropriate type.
The code looks like this:
class mem_entry extends uvm_object;
   int m_addr;
   int m_data;
class memory extends uvm_object;
   uvm_queue#(mem_entry) ml_mem_array[2];
   function new (string name = "memory");
      super.new(name);
   function mem_entry get_mem_entry(int a_addr, int mem_id);
      int v_size;
      int ii;
      v_size = ml_mem_array[mem_id].size();
     if ((mem_id >= 2) || (v_size == 0))
        return null;
      for (ii=0 ; ii<=(v_size-1) ; ii=ii+1)
             return ml_mem_array[mem_id][ii];
      return null;
In reply to Tamir:
You need to use the get() method of uvm_queue to access the internal queue elements
 for (int ii=0 ; ii<=(v_size-1) ; ii=ii+1)
       mem_entry entry = ml_mem_array[mem_id].get(ii);
       if (entry.m_addr == a_addr)
         return entry;
Thanks Dave, this solved my issue.
BTW, is it possible to replace the for loop with foreach loop ?
What is the syntax ?
In reply to Tamir:
You cannot use a foreach loop because the queue is protected inside the uvm_queue class
