In reply to mlsxdx:
Your problem is that you are not assigning names to your components when constructing them. The COMP_1234 names are created so that the testbench hierarchy can be properly constructed. You did this properly for driver and sequencer, but I’m guessing you did not do this for the pkt_env and test. Try this example
import uvm_pkg::*;
`include "uvm_macros.svh"
class pkt_env extends uvm_env;
`uvm_component_utils(pkt_env)
super.new(name, parent);
virtual function void connect_phase(uvm_phase phase);
`uvm_info(get_type_name(), "connect_phase() type name", UVM_LOW)
`uvm_info(get_full_name(), "connect_phase() full name", UVM_LOW)
$display({"full name: ", get_full_name()});
endclass : pkt_env
module top;
pkt_env p1,p2;
p1 = new("p1", null);
p1.connect_phase(null);
p2 = new("", null); // no name
p2.connect_phase(null);
endmodule : top
