Hi all, I am a beginner in UVM and trying a simple code to randomize two variable but getting some unwanted errors.Any suggesting will be appreciated.
//=========== code starts here ============//
`include "uvm_macros.svh"
package my_pkg;
import uvm_pkg::*;
//sequence_item class
class my_transaction extends uvm_sequence_item;
`uvm_object_utils(my_transaction)
rand logic [3:0] a;
rand byte b;
constraint c_a {a>5;a<15;}
constraint c_b {b>0;b<10;}
function new(string name = "");
super.new(name);
//sequence class
class my_sequence extends uvm_sequence #(my_transaction);
`uvm_object_utils(my_sequence)
my_transaction req;
super.new(name);
task body();
repeat(10) begin
req=my_transaction::type_id::create("req");
start_item(req);
if (!req.randomize()) begin
`uvm_fatal("MY_SEQUENCE", "Randomize failed.");
$display("a=%0d b=%0d",req.a,req.b);
finish_item(req);
class sequencer extends uvm_sequencer #(my_transaction);
`uvm_component_utils(sequencer)
function new(string name,uvm_component parent=null);
super.new(name,parent);
class driver extends uvm_driver #(my_transaction);
`uvm_component_utils(driver)
//test class
`uvm_component_utils(my_test)
my_sequence seq;
sequencer ss;
driver div;
seq=my_sequence::type_id::create("seq");
ss=sequencer::type_id::create("ss",this);
div=driver::type_id::create("div",this);
div.seq_item_port.connect(ss.seq_item_export);
phase.raise_objection(this);
seq.start(ss);
phase.drop_objection(this);
endpackage : my_pkg
module tb();
import my_pkg::*;
import uvm_pkg::*;
run_test("my_test");
//================== END ==================//
