When is "Compiling package uvm_sv_unit" triggered in vlog compile?
In reply to Tudor Timi:
By UVM harness I am referring to something based on: http://www.synapse-da.com/Uploads/PDFFiles/03_UVM-Harness.pdf, a method of connecting the uvm environment and the dut that uses interfaces and binds with the module-side.
Let’s define the environment terms first:
1.) top_dut = design under test w/ submod_1 and submod_2 having signals corresponding to my_if_1 and my_if_2
2.) my_env = uvm environment
3.) my_cfg = environment config contains virtual interfaces; agent_1 and agent_2 have corresponding cfg_1 and cfg_2
4.) my_if_1 = interface set 1 connects w/ agent_1
5.) my_if_2 = interface set 2 connects w/ agent_2
6.) my_harness = uvm harness that connects submod_1 and submod_2 to my_if_1 and my_if_2 respectively
7.) top_tb = for testbench top
The source code looks like this:
1.) top_dut
module modcore;
  wire clk1;
  wire valid1;
  wire ready1;
  wire clk2;
  wire addr2;
  wire byten2;
  submod_1 u_submod_1 (.submod_1_clk(clk1),
                       .submod_1_valid(valid1),
                       .submod_1_ready(ready1));
  submod_2 u_submod_2 (.submod_2_clk(clk2),
                       .submod_2_addr(addr2),
                       .submod_2_byten(byten2));
module top_dut;
  wire clk1;
  wire clk2;
  wire valid1;
  wire ready1;
  wire addr2;
  wire byten2;
  modcore u_modcore(.clk1(clk1),
                    .clk2(clk2),
                    .valid1(valid1),
                    .ready1(ready1),
                    .addr2(addr2),
                    .byten2(byten2)
2.) my_env
class my_env extends uvm_env;
  `uvm_component_utils(my_env)
  my_agent1 u_agent1;
  my_agent2 u_agent2;
  my_cfg    u_cfg;
    // Agent 1
    if(this.u_agent1 == null) begin
      this.u_agent1 = my_agent1::type_id::create("u_agent1",this);
      uvm_config_db#(agent1_cfg)::set(
        .cntxt       (this),
        .inst_name   ("u_agent1*"),
        .field_name  ("agent1_cfg"),
        .value       (this.cfg.u_cfg_1)
    // Agent 2
    if(this.u_agent2 == null) begin
      this.u_agent2 = my_agent2::type_id::create("u_agent2",this);
      uvm_config_db#(agent2_cfg)::set(
        .cntxt       (this),
        .inst_name   ("u_agent2*"),
        .field_name  ("agent2_cfg"),
        .value       (this.cfg.u_cfg_2)
  endfunction : build_phase
endclass : my_env
3.) my_cfg
class my_cfg extends uvm_object;
  `uvm_object_utils(my_cfg)
            cfg_1 u_cfg_1;
            cfg_2 u_cfg_2;
  function void build();
    if (u_cfg_1 == null) begin
      this.u_cfg_1 = cfg1::type_id::create("u_cfg_1");
    if (u_cfg_2 == null) begin
      this.u_cfg_2 = cfg2::type_id::create("u_cfg_2");
  endfunction : build
endclass : my_cfg
4.) my_if_1
interface my_if_1 ();
  wire clk;
  wire my_if_1_valid;
  wire my_if_1_ready;
  clocking my_if_1_cb @(posedge clk);
    input my_if_1_valid;
    output ready;
  endclocking
  modport my_if_1_mp (clocking my_if_1_cb,
                      input clk);
endinterface : my_if_1
`define my_if_1_bind(VIF, PATH, CLK, VALID, READY)\
  alias VIF.clk           = PATH.CLK; \
  alias VIF.my_if_1_valid = PATH.VALID; \
  alias VIF.my_if_1_ready = PATH.READY;
5.) my_if_2
interface my_if_2 ();
  wire clk;
  wire my_if_2_addr; // don't mind the bit widths
  wire my_if_2_byten;
  clocking my_if_2_cb @(posedge clk);
    input my_if_2_addr;
    output my_if_2_byten;
  endclocking
  modport my_if_2_mp (clocking my_if_2_cb,
                      input clk);
endinterface : my_if_2
`define my_if_2_bind(VIF, PATH, CLK, ADDR, BYTEN)\
  alias VIF.my_if_2_addr  = PATH.ADDR; \
  alias VIF.my_if_2_byten = PATH.BYTEN;
6.) my_harness
`include "my_if_1.sv"
`include "my_if_2.sv"
interface my_harness ();
  my_if_1 u_if_1 ();
  my_if_2 u_if_2 ();
  `my_if_1_bind(u_if_1, u_modcore.u_submod_1, clk1, valid1, ready1)
  `my_if_2_bind(u_if_2, u_modcore.u_submod_2, clk2, addr2, byten2)
endinterface
bind u_modcore my_harness harness();
7.) top_tb
import uvm_pkg::*;
`include "my_harness.sv"
module top_tb;
    uvm_config_db#(virtual my_harness)::set(
      .cntxt      (null),
      .inst_name  ("uvm_test_top"),
      .field_name ("my_harness"),
      .value      (top_dut.u_modcore.harness)
Let me change the error as follows to correspond with the signal names:
**Error: /some_path/my_harness.sv(100): (vlog-LRM-2230) Expression ‘my_if.my_if_1_valid’ is not allowed in alias statement.
Thanks,
Martin
