What is the right way to feed sequence data into a text file from driver?
I am trying to write data into a text file at runtime from the driver. The data is being generated from the sequencer and being taken by the driver. The driver takes this data is appends it to the file.
Here is a code snippet of what I’m doing in the run phase of the driver"
    reg[15:0]mem[0:18];
    int fin;
	int i;
    bit [15:0]eop=16'hFFFF;
//Set initial instructions.txt file
	mem[0]=16'h9A35;
 	mem[1]=16'h9A7F;
        mem[2]=16'h9A85;
        mem[3]=16'h9AC0;
        mem[4]=16'h9B0B;
        mem[5]=16'h9B73;
        mem[6]=16'h9BBC;
        mem[7]=16'h9BC1;
        mem[8]=16'h9C04;
        mem[9]=16'h9C40;
        mem[10]=16'h9C81;
        mem[11]=16'h9CEB;
        mem[12]=16'h9D11;
        mem[13]=16'h9D40;
        mem[14]=16'h9D82;
        mem[15]=16'h9DD4;
        mem[16]=16'hEFFF;
        mem[17]=16'hEFFF;
        mem[18]=16'hEFFF;
    $writememh("instructions.txt",mem);
    // Now drive normal traffic
    forever begin
    fin=$fopen("instructions.txt","a");
    $fdisplayh(fin,req.instrn);
    //$fdisplayh(fin,eop);
    $fclose(fin);
`uvm_info ("PASS ", $sformatf("Value=%h \n",req.instrn), UVM_LOW)
	for(i=0;i<25;i++)begin
//	    processor_vif.driver_if_mp.driver_cb.ps_clk<=drv_clk;
	    processor_vif.driver_if_mp.ps_clk<=drv_clk;
	    #5;
	    drv_clk = ~drv_clk;
      // call the write method of implementation port in scoreboard to
      // broadcast input values
      Drv2Sb_port.write(req);
      seq_item_port.item_done();
I intend for the data to be written into the text file and then the driver drives the clock to the dut for some clock cycles and then a new line of data is appended to the text file.
Note that the driver uses this data from the text file and then performs some operations.
When I run this code only the last sequence in the text file gets written and consumed by the DUT.
In reply to gupta409:
It looks you have correct codes to write mem into test file and append one data per loop to text file. I reproduced your codes simply as below and it works. The only differences are that 1) I use randomize(instrn_wr) to replace your transaction item “req.instrn” and 2) I add read text file paragraph to show the data appended correctly.
Can you please clarify what do you mean
Have you seen req.instrn value change with the uvm_info message?
import uvm_pkg::*;
`include "uvm_macros.svh"
module tb();
  initial run_phase();
  task run_phase();
    bit drv_clk;
    reg[15:0]mem[0:18];
    int fin;
    int i;
    //bit [15:0] eop =16'hFFFF;
    bit [15:0] instrn_wr, instrn_rd;
    int loop;
    integer code;
    mem[0]=16'h9A35;
    mem[1]=16'h9A7F;
    mem[2]=16'h9A85;
    mem[3]=16'h9AC0;
    mem[4]=16'h9B0B;
    mem[5]=16'h9B73;
    mem[6]=16'h9BBC;
    mem[7]=16'h9BC1;
    mem[8]=16'h9C04;
    mem[9]=16'h9C40;
    mem[10]=16'h9C81;
    mem[11]=16'h9CEB;
    mem[12]=16'h9D11;
    mem[13]=16'h9D40;
    mem[14]=16'h9D82;
    mem[15]=16'h9DD4;
    mem[16]=16'hEFFF;
    mem[17]=16'hEFFF;
    mem[18]=16'hEFFF;
    while (loop<=3) begin
      void'(randomize(instrn_wr));
      $fdisplayh(fin, instrn_wr);
      $fclose(fin);
      `uvm_info ("PASS ", $sformatf("loop=%0d instrn_wr=%h",loop, instrn_wr), UVM_LOW)
      //-----------------read the text file to show data appended--------
      fin=$fopen("instructions.txt","r");
      while(!$feof(fin)) begin
        code = $fscanf(fin, "%0h", instrn_rd);
        //if (loop==3)  //open these two lines will show the whole text file contents @loop 3
        //  `uvm_info ("PASS ", $sformatf("loop=%0d instrn_rd=%h",loop, instrn_rd), UVM_LOW)
      $fclose(fin);
	    #5;
	    drv_clk = ~drv_clk;
      loop++;
Simulation log:
UVM_INFO testbench.sv(45) @ 0: reporter [PASS ] loop=0 instrn_wr=2964
UVM_INFO testbench.sv(55) @ 0: reporter [PASS ] loop=0 instrn_rd=2964
UVM_INFO testbench.sv(45) @ 125: reporter [PASS ] loop=1 instrn_wr=080b
UVM_INFO testbench.sv(55) @ 125: reporter [PASS ] loop=1 instrn_rd=080b
UVM_INFO testbench.sv(45) @ 250: reporter [PASS ] loop=2 instrn_wr=4e3c
UVM_INFO testbench.sv(55) @ 250: reporter [PASS ] loop=2 instrn_rd=4e3c
UVM_INFO testbench.sv(45) @ 375: reporter [PASS ] loop=3 instrn_wr=2eff
UVM_INFO testbench.sv(55) @ 375: reporter [PASS ] loop=3 instrn_rd=2eff
BTW, you may need to add super.run_phase(phase) to your run_phase task code
