What is "Hierarchical Constraints" in system verilog?
Can anybody explain me what is “hierarchical constraints” in system verilog ?
Thanks in advance.
Regards,
Chetan Shah
In reply to cashah85:
Hello,
I’m not sure if you have found this paper online http://events.dvcon.org/2015/proceedings/papers/04P_11.pdf
It explains the concept from the paper itself which in the LRM is referred as Global constraints
“… A class may declare an object
member (i.e. class instance) as “rand”. When the top-level object is randomized, the lower level objects are also randomized. All rand variables and constraints in the top- and lower-level objects are solved simultaneously…”
The exact example from the IEEE 1800-2012 SV LRM section 18.5.9 Global constraints
“…Constraint expressions involving random variables from other objects are called global constraints…”
class A;
rand bit [7:0] v;
class B extends A;
rand A left;
rand A right;
constraint heapcond {left.v <= v; right.v > v;}
In this code when you randomise an instance of B the solver will solve B and its left and right children simultaneously.
I hope this is what you meant by hierarchical constraints.
-R
