UVM_INFO @ 0: reporter [RNTST] Running test test…
UVM_FATAL …/Test/test.sv(46) @ 0: uvm_test_top [Write22 TEST CONFIG] FAILED
class test extends uvm_test;
`uvm_component_utils(test)
environ env;
wragent mas_agent;
rdagent sa_agent;
wrconfigure wrcfg;
rdconfigure rdcfg;
virsequence vseq;
configure envcfg;
bit has_magent=1;
bit has_sagent=1;
extern function new (string name = "test", uvm_component parent);
extern function void build_phase(uvm_phase phase);
//extern task run_phase(uvm_phase phase);
extern function void end_of_elaboration_phase(uvm_phase phase);
endclass: test
function test::new(string name = "test", uvm_component parent);
super.new(name,parent);
endfunction: new
function void test::build_phase(uvm_phase phase);
super.build_phase(phase);
env=environ::type_id::create("env",this);
envcfg=configure::type_id::create("envcfg");
wrcfg=wrconfigure::type_id::create("wrcfg");
rdcfg=rdconfigure::type_id::create("rdcfg");
if(has_magent)
wrcfg.is_active = UVM_ACTIVE;
if(!uvm_config_db #(virtual interfa)::get(this,"","intff",wrcfg.intff))
`uvm_fatal("Write22 TEST CONFIG","FAILED");
uvm_config_db #(wrconfigure)::set(this,"*","wrconfigure",wrcfg);
wrcfg=envcfg.wrcfg;
if(has_sagent)
rdcfg.is_active = UVM_ACTIVE;
if(!uvm_config_db #(virtual interfa)::get(this,"","intff",rdcfg.intff))
`uvm_fatal("READ TEST CONFIG","FAILED");
uvm_config_db #(rdconfigure)::set(this,"*","rdconfigure",rdcfg);
rdcfg=envcfg.rdcfg;
envcfg.has_magent=has_magent;
envcfg.has_sagent=has_sagent;
uvm_config_db #(configure)::set(this,"*","configure",envcfg);
endfunction: build_phase
function void test::end_of_elaboration_phase(uvm_phase phase);
uvm_top.print_topology();
/*task test::run_phase(uvm_phase phase);
phase.raise_objection(this);
vseq.start(env.vseqrh);
phase.drop_objection(this);
endtask: run_phase*/
class test1 extends test;
`uvm_component_utils(test1)
extern function new (string name = "test1", uvm_component parent);
endclass: test1
function test1::new(string name = "test1", uvm_component parent);
endfunction: new
function void test1::build_phase(uvm_phase phase);
task test1::run_phase(uvm_phase phase);
vseq=virsequence::type_id::create("vseq");
endtask: run_phase
