Wb_mac_config_vif_pm code example gives me # ** Fatal: (SIGSEGV) Bad handle or reference
I tried running one of the working uvm test cases to help me understand virtual interfaces (wb_mac_config_vif_pm), but ran into problems.
After adding a couple of missing variable definitions to get past compile errors:
virtual class wb_mem_map_access_base_seq extends uvm_sequence;
snip…
int unsigned m_mac_wb_base_addr; // added by RLHS
int unsigned m_tb_addr; // added by RLHS
I got the error below, which looks like get_register_map failed, I’m not sure how to repair this code, called from class method ‘new’.
–Ross
UVM_WARNING @ 0: reporter [TPRGED] Type name ‘wb_mem_map_access_base_seq’ already registered with factory. No string-based lookup support for multiple types with the same type name.
UVM_INFO verilog_src/questa_uvm_pkg-1.2/src/questa_uvm_pkg.sv(215) @ 0: reporter [Questa UVM] QUESTA_UVM-1.2.2
UVM_INFO verilog_src/questa_uvm_pkg-1.2/src/questa_uvm_pkg.sv(217) @ 0: reporter [Questa UVM] questa_uvm::init(+struct)
UVM_INFO @ 0: reporter [RNTST] Running test test_mac_simple_duplex…
UVM_INFO ./wishbone/wb_mac_reg_scoreboard.svh(76) @ 195: uvm_test_top.env.mac_regs [REG_MON]
---- Did a shadow reg write to register_map.mac_0_regs.mode_reg
UVM_INFO ./wishbone/wb_mac_reg_scoreboard.svh(76) @ 273: uvm_test_top.env.mac_regs [REG_MON]
---- Did a shadow reg write to register_map.mac_0_regs.mac_addr0_reg
UVM_INFO ./wishbone/wb_mac_reg_scoreboard.svh(76) @ 351: uvm_test_top.env.mac_regs [REG_MON]
---- Did a shadow reg write to register_map.mac_0_regs.mac_addr1_reg
UVM_INFO ./wishbone/wb_mac_reg_scoreboard.svh(76) @ 429: uvm_test_top.env.mac_regs [REG_MON]
---- Did a shadow reg write to register_map.mac_0_regs.int_mask_reg
** Fatal: (SIGSEGV) Bad handle or reference.
Time: 429 ns Iteration: 12 Process: /sequences_pkg::mac_simple_duplex_seq::body/fork#70_55a0138 File: ./mac_mii/mac_mii_base_frame_seq.svh
Fatal error in Function uvm_pkg/uvm_component::get_config_object at /mrvl2g/caev15/eda10/MENTOR/QUESTASIM/10.3f/questasim/linux/../verilog_src/uvm-1.1d/src/base/uvm_component.svh line 2941
HDL call sequence:
Stopped at ./mac_mii/mac_mii_base_frame_seq.svh 110 Function uvm_pkg/uvm_component::get_config_object
called from ./mac_mii/mac_mii_base_frame_seq.svh 49 Function mac_mii_pkg/wb_mem_map_access_base_seq::new
called from ./mac_mii/mac_tx_frame_seq.svh 42 Function mac_mii_pkg/mac_tx_frame_seq::new
called from /mrvl2g/caev15/eda10/MENTOR/QUESTASIM/10.3f/questasim/linux/../verilog_src/uvm-1.1d/src/base/uvm_registry.svh 199 Function uvm_pkg/uvm_object_registry::create_object
called from /mrvl2g/caev15/eda10/MENTOR/QUESTASIM/10.3f/questasim/linux/../verilog_src/uvm-1.1d/src/base/uvm_factory.svh 1104 Function uvm_pkg/uvm_factory::create_object_by_type
called from /mrvl2g/caev15/eda10/MENTOR/QUESTASIM/10.3f/questasim/linux/../verilog_src/uvm-1.1d/src/base/uvm_registry.svh 248 Function uvm_pkg/uvm_object_registry::create
called from ./sequences/mac_simple_duplex_seq.svh 191 Task sequences_pkg/mac_simple_duplex_seq::mac_tx_frame
called from ./sequences/mac_simple_duplex_seq.svh 70 Task sequences_pkg/mac_simple_duplex_seq::body
In reply to rossswanson:
Hi Ross, could you elaborate a little bit more about your problem. Is it one of the UVM cookbook examples and which one?
What worries me is this line of code:
What is your intention for this?
Christoph
The example down load name is in the original post see name between ();
This is supposedly a working exampole under the vif page, but it had compile problems right off the bat.
I copied the line of code that contains the failing problem.
To fix the issue, edit the file mac_mii/mac_mii_pkg.sv and comment out line 37:
 `include "uvm_macros.svh"
 `include "ethernet_txn.svh"
 `include "ethernet_txn_ext.svh"
 `include "mii_config.svh"
 `include "mii_tx_driver.svh"
 `include "mii_rx_driver.svh"
// `include "mac_mii_base_frame_seq.svh"  <-- Line 37
 `include "mac_rx_frame_seq.svh"
 `include "mac_tx_frame_seq.svh"
 `include "mac_mii_tx_agent.svh"
 `include "mac_mii_rx_agent.svh"
 `include "mac_mii_duplex_agent.svh"
 `include "mii_scoreboard.svh"
In reply to cgales:
Hi
I commented out the line and ran vlog on the files within vsim -c
but got exact same error.
I then tried make clean followed by make cmp but got a bunch of errors that go off the screen, I can not find the first error, not enough lines in my xterm. I do not see a log file when I run the make file. This is why I run from vsim -c I suppose I could try tee on the make.
One of the errors from running the make is:
** Error: ./sequences/sequences_pkg.sv(28): (vlog-13006) Could not find the package (mac_mii_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
** Error: ** while parsing file included at ./sequences/sequences_pkg.sv(33)
snip…
// “global” virtual interface
virtual mii_if v_miim_if;
include "uvm_macros.svh" include “ethernet_txn.svh”
include "ethernet_txn_ext.svh" include “mii_config.svh”
include "mii_tx_driver.svh" include “mii_rx_driver.svh”
//RLHS from cgales include "mac_mii_base_frame_seq.svh" include “mac_rx_frame_seq.svh”
`include “mac_tx_frame_seq.svh”
–Ross
I did a tee and see the first error when running from make
– Importing package mac_info_pkg
– Importing package wishbone_pkg
** Error: ** while parsing file included at ./mac_mii/mac_mii_pkg.sv(39)
** at ./mac_mii/mac_tx_frame_seq.svh(137): near “;”: syntax error, unexpected ‘;’, expecting ‘(’
** at ./mac_mii/mac_tx_frame_seq.svh(160): (vlog-2730) Undefined variable: ‘error’.
** at ./mac_mii/mac_tx_frame_seq.svh(161): (vlog-2730) Undefined variable: ‘retry_count’.
** at ./mac_mii/mac_tx_frame_seq.svh(168): (vlog-2730) Undefined variable: ‘tx_irq’.
My guess is that you made other changes as well. Start with the original download and make the one change I specified. With that change, everything works fine for me.
In reply to cgales:
I only added
./mac_mii/mac_mii_base_frame_seq.svh: int unsigned m_mac_wb_base_addr; // added by RLHS
./mac_mii/mac_mii_base_frame_seq.svh: int unsigned m_tb_addr; // added by RLHS
I’ll download again…
Downloaded again edited pkg to comment out line 37 base frame seq and got error below from make:
Loading work.mii_if(fast)
** Fatal: (vsim-8451) ./wishbone/wb_bus_bfm_monitor.svh(56): Virtual interface resolution cannot find a matching instance for ‘virtual wishbone_bus_bfm_if’.
Global interface ‘wishbone_bus_bfm_if’ expected.
Non-matching nested interface from ‘wb_bus_wrapper’ has instances:
./wishbone/wb_bus_wrapper.sv(157): wishbone_bus_bfm_if #() wb_bus_bfm_if()
Time: 0 ns Iteration: 0 Region: /wishbone_pkg File: ./wishbone/wb_mac_reg_scoreboard.svh
FATAL ERROR while loading design
Error loading design
End time: 13:46:22 on Mar 30,2016, Elapsed time: 0:00:03
Errors: 1, Warnings: 0
SUNGRID >> ERROR : Job Exited.
Exit code is: 12
make: *** [sim] Error 12
Hi Ross, did you delete the old compiled library?
After making the change cgales was advicing, it works in my environment.
Hi
I put the tar extract into a new dir so the work dir is new.
I thought it might be version dependent I was running 10.3f, I changed to 10.5 and got same error.
Maybe I need to specify 64 bit…
didn’t make a difference.
Hi Ross,
it looks like something is wrong with your setup. Could you please check if the environment variable UVM_HOME is set?
Additionally you could try to download any other example and try to run it.
The make file sets this up
UVM_HOME ?= /proj/eda/MENTOR/QUESTASIM/10.4d/questasim/verilog_src/uvm-1.1d
UVM_SRC = $(UVM_HOME)/src
ls -al $UVM_SRC
-r–rwxr-- 1 i eda 1304 Dec 29 21:27 uvm_pkg.sv*
-r–rwxr-- 1 i eda 2121 Dec 29 21:27 uvm_macros.svh*
-r–rwxr-- 1 i eda 944 Dec 29 21:27 uvm.sv*
drwxrwxr-x 2 i eda 4096 Jan 18 16:50 base/
drwxrwxr-x 2 i eda 4096 Jan 18 16:50 comps/
drwxrwxr-x 2 i eda 4096 Jan 18 16:50 deprecated/
drwxrwxr-x 2 i eda 4096 Jan 18 16:50 dpi/
drwxrwxr-x 2 i eda 4096 Jan 18 16:50 macros/
drwxrwxr-x 3 i eda 4096 Jan 18 16:50 reg/
drwxrwxr-x 2 i eda 4096 Jan 18 16:50 seq/
drwxrwxr-x 2 i eda 4096 Jan 18 16:50 tlm1/
drwxrwxr-x 2 i eda 4096 Jan 18 16:50 tlm2/
Hi Ross, the UVM source code looks pretty good.
But I had a deeper look to the code.
The error message you have posted above:
Can not be from the example ‘wb_mac_config_vif_pm’. There is no file named ./wishbone/wb_bus_bfm_monitor.svh
Could you please check again.
Hi
Yes sorry about the confusion. There are two gz downloads on that vif page and I was trying the other one.
Below is what I get after executing make:
QuestaSim vlog 10.5 Compiler 2016.02 Feb 12 2016
Start time: 14:05:34 on Mar 31,2016
vlog -suppress 2223 -suppress 2181 ./wishbone/wb_slave_mem.sv ./wishbone/wishbone_bus_syscon_if.sv ./top_modules/test_params_pkg.sv ./mac_mii/mii_if.sv ./mac_mii/mac_mii_protocol_module.sv ./eth/wb_register_pkg.sv ./eth/mac_info_pkg.sv ./wishbone/wishbone_pkg.sv ./mac_mii/mac_mii_pkg.sv ./sequences/sequences_pkg.sv ./env/env_pkg.sv ./tests/tests_pkg.sv ./top_modules/top_mac.sv “+incdir+./wishbone” “+incdir+./eth” “+incdir+./sequences” “+incdir+./mac_mii” “+incdir+./tests” “+incdir+./env” “+incdir+./uvm/src/uvm_register-2.0/src” “+incdir+/proj/eda/MENTOR/QUESTASIM/10.4d/questasim/verilog_src/uvm-1.1d/src”
– Compiling module wb_slave_mem
– Importing package mtiUvm.uvm_pkg (uvm-1.1d Built-in)
– Compiling package wishbone_bus_syscon_if_sv_unit
– Compiling interface wishbone_bus_syscon_if
– Compiling package test_params_pkg
– Compiling interface mii_if
– Compiling module mac_mii_protocol_module
– Compiling package wb_register_pkg
– Importing package uvm_register_pkg
– Compiling package mac_info_pkg
– Compiling package wishbone_pkg
– Importing package wb_register_pkg
– Compiling package mac_mii_pkg
** Error: (vlog-13069) ** while parsing file included at ./mac_mii/mac_mii_pkg.sv(39)
** at ./mac_mii/mac_tx_frame_seq.svh(137): near “;”: syntax error, unexpected ‘;’, expecting ‘(’.
** at ./mac_mii/mac_tx_frame_seq.svh(144): Illegal declaration after the statement near line ‘137’. Declarations must precede statements. Look for stray semicolons.
– Compiling package sequences_pkg
** Error: ./sequences/sequences_pkg.sv(25): (vlog-13006) Could not find the package (mac_mii_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
** Error: ./sequences/sequences_pkg.sv(27): (vlog-13006) Could not find the package (mac_mii_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
** at ./sequences/mac_simple_duplex_seq.svh(34): (vlog-2730) Undefined variable: ‘ethernet_txn’.
** at ./sequences/mac_simple_duplex_seq.svh(44): Invalid type ‘ethernet_txn’. Please check the type of the variable ‘eth_rsp_txn’.
** Error: (vlog-13069) ** while parsing file included at ./sequences/sequences_pkg.sv(33)
** at ./sequences/mac_simple_duplex_seq.svh(130): near “;”: syntax error, unexpected ‘;’, expecting ‘(’.
** at ./sequences/mac_simple_duplex_seq.svh(132): Illegal declaration after the statement near line ‘130’. Declarations must precede statements. Look for stray semicolons.
** at ./sequences/mac_simple_duplex_seq.svh(135): near “end”: syntax error, unexpected end.
snip…
Hi Ross, no problem. Let’s go ahead to find the solution.
The error message in the compile shows us the type tx_bd_t is not defined.
But tx_bd_t is defined in ./eth/wb_register_pkg.sv.
I’m not sure if you were pasting the whole log of the compile into your message. My make log looks like this (cutting out the simulation part):
make
rm -rf *.tmp *.log log transcript work *.wlf vsim.fcdb .vstf
find . -name "
test -e work || vlib work
vlog +incdir+/opt/questa/current/questasim/verilog_src/uvm-1.1d/src +incdir+./uvm/src/uvm_register-2.0/src ./uvm/src/uvm_register-2.0/src/uvm_register_pkg.sv
QuestaSim-64 vlog 10.4c Compiler 2015.07 Jul 19 2015
Start time: 08:23:05 on Apr 01,2016
vlog “+incdir+/opt/questa/current/questasim/verilog_src/uvm-1.1d/src” “+incdir+./uvm/src/uvm_register-2.0/src” ./uvm/src/uvm_register-2.0/src/uvm_register_pkg.sv
– Compiling package uvm_register_pkg
Top level modules:
–none–
End time: 08:23:06 on Apr 01,2016, Elapsed time: 0:00:01
Errors: 0, Warnings: 0
vlog +incdir+./mac_core -y ./mac_core +libext+.v ./mac_core/eth_top.v
Start time: 08:23:06 on Apr 01,2016
vlog “+incdir+./mac_core” -y ./mac_core “+libext+.v” ./mac_core/eth_top.v
– Compiling module eth_top
– Scanning library directory ‘./mac_core’
– Compiling module eth_miim
– Compiling module eth_registers
– Compiling module eth_maccontrol
– Compiling module eth_txethmac
– Compiling module eth_rxethmac
– Compiling module eth_wishbone
– Compiling module eth_macstatus
– Compiling module eth_clockgen
– Compiling module eth_shiftreg
– Compiling module eth_outputcontrol
– Compiling module eth_receivecontrol
– Compiling module eth_transmitcontrol
– Compiling module eth_txcounters
– Compiling module eth_txstatem
– Compiling module eth_crc
– Compiling module eth_random
– Compiling module eth_rxstatem
– Compiling module eth_rxcounters
– Compiling module eth_rxaddrcheck
– Compiling module eth_spram_256x32
– Compiling module eth_fifo
Top level modules:
eth_top
End time: 08:23:06 on Apr 01,2016, Elapsed time: 0:00:00
+incdir+./wishbone
+incdir+./eth
+incdir+
+incdir+
+incdir+./sequences
+incdir+./mac_mii
+incdir+./tests
+incdir+./env
vlog -suppress 2223 -suppress 2181 ./wishbone/wb_slave_mem.sv ./wishbone/wishbone_bus_syscon_if.sv ./top_modules/test_params_pkg.sv ./mac_mii/mii_if.sv ./mac_mii/mac_mii_protocol_module.sv ./eth/wb_register_pkg.sv ./eth/mac_info_pkg.sv ./wishbone/wishbone_pkg.sv ./mac_mii/mac_mii_pkg.sv ./sequences/sequences_pkg.sv ./env/env_pkg.sv ./tests/tests_pkg.sv ./top_modules/top_mac.sv “+incdir+./wishbone” “+incdir+./eth” “+incdir+” “+incdir+” “+incdir+./sequences” “+incdir+./mac_mii” “+incdir+./tests” “+incdir+./env” “+incdir+./uvm/src/uvm_register-2.0/src” “+incdir+/opt/questa/current/questasim/verilog_src/uvm-1.1d/src”
– Importing package mac_mii_pkg
– Compiling package env_pkg
– Compiling package tests_pkg
– Importing package env_pkg
– Importing package sequences_pkg
– Importing package test_params_pkg
– Compiling module top_mac
– Importing package tests_pkg
Top level modules:
top_mac
Could you please check that all the stuff in folder eth was compiled.
The vlog command with argument is the same.
The simulator output of the vlog differs, shown below mine is on the left
– Compiling module wb_slave_mem – Compiling module wb_slave_mem
– Importing package mtiUvm.uvm_pkg (uvm-1.1d Built-in) – Importing package mtiUvm.uvm_pkg (uvm-1.1d Built-in)
– Compiling package wishbone_bus_syscon_if_sv_unit – Compiling interface wishbone_bus_syscon_if
– Importing package mtiUvm.uvm_pkg (uvm-1.1d Built-in) – Compiling package wishbone_bus_syscon_if_sv_unit
– Compiling interface wishbone_bus_syscon_if – Importing package mtiUvm.uvm_pkg (uvm-1.1d Built-in)
– Compiling package test_params_pkg – Compiling interface wishbone_bus_syscon_if
– Compiling interface mii_if – Compiling package test_params_pkg
– Compiling module mac_mii_protocol_module – Compiling interface mii_if
– Compiling package wb_register_pkg – Compiling module mac_mii_protocol_module
– Importing package uvm_register_pkg – Compiling package wb_register_pkg
– Compiling package mac_info_pkg – Importing package uvm_register_pkg
– Compiling package wishbone_pkg – Compiling package mac_info_pkg
– Importing package wb_register_pkg – Compiling package wishbone_pkg
– Compiling package mac_mii_pkg – Importing package wb_register_pkg
– Importing package mac_info_pkg – Compiling package mac_mii_pkg
– Importing package wishbone_pkg – Importing package mac_info_pkg
** Error: (vlog-13069) ** while parsing file included at – Importing package wishbone_pkg
The first difference is this line
I’m surprised the compile sequence causes the Error. I could change the vlog command in the make so the compile sequence is the same? Let me know.
–Ross
PS Thanks for the help.
I don’t believe the problem is the sequence of the compile steps.
The first error message you get is:
Line 137 is:
tx_bd_t txbd;
The compiler complains about missing (. This is an indication that tx_bd_t is not existing/known.
I have extracted the vlog commands from the make execution.
See the commands below.
+incdir+./wishbone
+incdir+./eth
+incdir+
+incdir+
+incdir+./sequences
+incdir+./mac_mii
+incdir+./tests
+incdir+./env
vsim +nowarnTSCALE -voptargs=“+acc” top_mac -suppress 3829
run -a
I’d like to ask you copy the commands in a file, may be named compile.do.
Adopt the paths which start with /opt/questa/current to your environment.
Then run from the command line
vsim -do compile.do &
Let me know if it works now.
