ldmldm
1
Hi All,
I need to declare the following Look Up Table:
…C2 … C1 … C0
L0…t0 … t1 … t2
L1…t2 … t1 … t0
L2…t1 … t0 … t2
where t0, t1 and t2 are enum elements of the LUT.
Each element of the LUT should be referenced by (L*,C*), which are also of enum type.
Ex:
LUT(C2,L0) should refer to t0
LUT(C1,L1) should refer to t1
LUT(C0,L2) should refer to t2
So, how should I define this LUT? How should I refer the elements in the LUT?
Thank you!
dave_59
2
In reply to dmitryl:
typedef enum {C[0:2]} C_e;
typedef enum {L[0:2]} L_e;
typedef enum {t[0:2]} t_e;
t_e LUT[L_e][C_e];
LUT = '{L0:'{C2:t0, C1:t1, C0:t2},
L1:'{C2:t2, C1:t1, C0:t0},
L2:'{C2:t1, C1:t0, C0:t2} };
// or
LUT[L0][C0] = t0;
LUT[L0][C1] = t1;
ldmldm
3
Is there a way to define a type of/for the LUT using typedef ?
Could it be written as following?
typedef enum t_e[L_e][C_e] LUT_e;
and then to declare the LUT array:
LUT_e LUT;
And one another thing… According to to your example, C[0] is the same as C0… Is that true?
The elements of C_e are C[0], C[1], C[2] or C0, C1, C2**?**
And one another thing… :-)
If I would define C_e as typedef enum {a,b,c} C_e; then could LUT be defined in the same maner as you wrote:
t_e LUT[L_e][C_e];
Your help is appreciated
