I am combining Simple UVM testbench and Hello world from EDA playground. I am using the binding mechanism which is in simple testbench in Hello world.
I am getting this warning during compilation, and when I simulate I get the error.
Please find the code attached along with the warning and error.
---------------------design.sv -------------------
`include “uvm_macros.svh”
module dut(
input clock,
input reset,
input cmd,
input [7:0] addr,
input [7:0] data
import uvm_pkg::*;
always @(posedge clock)
if (reset != 1) begin
`uvm_info(“DUT”,
$sformatf(“Received cmd=%b, addr=0x%2h, data=0x%2h”,
cmd, addr, data), UVM_MEDIUM)
interface dut_if(
input bit clock,
input reset,
input cmd,
input [7:0] addr,
input [7:0] data
clocking cb @(posedge clock);
output reset;
output cmd;
output addr;
output data;
endclocking // cb
endinterface
bind dut dut_if dut_if12(
.clock(clock),
.reset(reset),
.cmd(cmd),
.addr(addr),
.data(data)
-------------- testbench.sv
This is a basic UVM “Hello World” testbench.
Explanation of this testbench on YouTube:
include "uvm_macros.svh" include “my_testbench_pkg.svh”
import uvm_pkg::;
import my_testbench_pkg::;
// The top module that contains the DUT and interface.
// This module starts the test.
bit clock;
dut dut1(.clock(clock));
// Clock generator
clock = 0;
forever #5 clock = ~clock;
// Place the interface into the UVM configuration database
uvm_config_db#(virtual dut_if)::set(null, “*”, “dut_if”, dut1.dut_if12);
// Start the test
run_test(“my_test”);
// Dump waves
$dumpfile(“dump.vcd”);
$dumpvars(0, top);
----------------- my driver.sv
class my_driver extends uvm_driver #(my_transaction);
`uvm_component_utils(my_driver)
virtual dut_if dut_vif;
super.new(name, parent);
// Get interface reference from config database
if(!uvm_config_db#(virtual dut_if)::get(this, “”, “dut_if”, dut_vif)) begin
`uvm_error(“”, “uvm_config_db::get failed”)
// First toggle reset
dut_vif.cb.reset <= 1;
@(dut_vif.cb);
#1;
dut_vif.cb.reset <= 0;
// Now drive normal traffic
forever begin
// Wiggle pins of DUT
dut_vif.cb.cmd <= req.cmd;
dut_vif.cb.addr <= req.addr;
dut_vif.cb.data <= req.data;
@(dut_vif.cb);
seq_item_port.item_done();
endclass: my_driver
Warning during compilation
** Warning: (vlog-2650) ‘bind’ found in compilation unit scope. Please use -cuname to ensure that ‘bind’ gets elaborated.
Error during simulation
arning: (vsim-3008) testbench.sv(30): [CNNODP] - Component name (dut_if12) is not on a downward path.
