Wait for signal value in a task with timeout
I would like to write a task that receives a signal by reference and waits for its posedge or negedge. If the signal is not set to the desired value within a specified timeout, an error message should be set.
I wrote something like this:
task automatic timeout(ref logic signal,input logic value,input time timeout_value);
      if(signal !== value) begin
                  #timeout_value;
                  `uvm_error(....
                  if (signal !== signal_value)
                     @(signal === signal_value);
           join_any
           disable fork;
This code does not compile because it violates Verilog LRM section 9.3.2(parallel blocks):it is illegal to refer to an argument passed by reference in fork - join_any block.
Do you have any suggestions? Maybe there is a solution for this in UVM? I could not find any.
In reply to shaygueta:
Just fork the timeout delay.
   bit timed_out;
           fork begin
                  #timeout_value;
                  `uvm_error(....
                  timed_out = '1;
             join_none
             wait(signal === value || timed_out);
             disable fork;
           end join
Note the enclosing fork/join is needed to prevent the disable fork from killing other child threads that may have been spawned before calling this task.
Why add another bit “timed_out” instead of using join_any?
           fork begin
                  #timeout_value;
                  `uvm_error(....
                  wait(signal === value);
             join_any
             disable fork;
           end join
In reply to Elisha K:
Because the reference to signal inside a fork/join_any or join_none is not legal.
bit timed_out;
fork begin
#timeout_value;
`uvm_error(....
timed_out = '1;
join_none
disable fork;
end join
HI Dave :
1 can I use disable {name of fork} instead of the guard fork/join here ? i.e
disable < name of fork process>; // assume there is name of fork/join_none
2. Do you recommend always use a guard fork/join when there is disable fork ? for example
in run_phase(uvm_phase phase);
In reply to VE:
  1. Using
    disable name_of_fork
    has problems if there are multiple concurrent instances of the fork. Since you are allowed to use
    from anywhere, it has no way of knowing which instance you mean and it kills all instances.
  2. I do recommend using guard fork/join whenever there is disable fork as a good habit. But you can avoid it if you are sure no other processes would get disabled accidentally. All of the UVM phase tasks are forked as a separate process so there are no other child process that could get disabled accidentally.
