In reply to megamind:
You need to go back and edit your post as your image is not visible. A link to EDAPlayground would be much better.
The 2 big differences between event controls @(posedge signal) and wait(signal)
- The transition from 0 to 1 must not have already happened for @(posedge signal) when encountering that event control. It really should read as “wait for the next transition to 1”
- wait(signal) will not block if signal is already 1. If you have this construct in a loop without any other blocking event controls, you get an infinite 0-delay loop.
So they only behave the same if signal is not 0 at the point when encountering either event control.
When you say that a signal is synchronous, that means you only want to sample its value on a clock edge. You would want to use @(posedge clk iff (signal))
