Hi everyone I am new in UVM and trying-testing the virtual sequencer constructs but caught by some unexpected error.Any suggestion will be appreciated.Thanks
click to edaLink
//============ code starts here =============//
//============ wb_agent ===========//
`include "uvm_macros.svh"
import uvm_pkg::*;
class wb_tx extends uvm_object;
bit [31:0] addr;
bit [31:0] data;
`uvm_object_utils_begin (wb_tx)
`uvm_field_int (addr, UVM_ALL_ON)
`uvm_field_int (data, UVM_ALL_ON)
`uvm_object_utils_end
function new (string name="wb_tx");
super.new (name);
class wb_driver extends uvm_driver;
`uvm_component_utils (wb_driver)
function new (string name="wb_driver", uvm_component parent);
super.new (name, parent);
virtual task main_phase (uvm_phase phase);
`uvm_info ("wb_DRV", $sformatf ("Starting %s", this.get_type_name()), UVM_FULL)
class wb_monitor extends uvm_monitor;
`uvm_component_utils (wb_monitor)
function new (string name="wb_monitor", uvm_component parent);
`uvm_info ("wb_MON", $sformatf ("Starting %s", this.get_type_name()), UVM_FULL)
class wb_rw_seq extends uvm_sequence;
`uvm_object_utils (wb_rw_seq)
function new (string name = "wb_rw_seq");
super.new (name);
task body ();
`uvm_info ("RW_SEQ", $sformatf ("Starting %s", this.get_type_name()), UVM_MEDIUM)
class wb_reset_seq extends uvm_sequence;
`uvm_object_utils (wb_reset_seq)
function new (string name = "wb_reset_seq");
super.new (name);
task body ();
`uvm_info ("RESET_SEQ", $sformatf ("Starting %s", this.get_type_name()), UVM_MEDIUM)
class wb_agent extends uvm_agent;
`uvm_component_utils (wb_agent)
wb_driver m_wb_drv;
wb_monitor m_wb_mon;
uvm_sequencer m_wb_seqr;
function new (string name="wb_agent", uvm_component parent);
function void build_phase (uvm_phase phase);
super.build_phase (phase);
m_wb_seqr = uvm_sequencer::type_id::create ("m_wb_seqr", this);
m_wb_drv = wb_driver::type_id::create ("m_wb_drv", this);
m_wb_mon = wb_monitor::type_id::create ("m_wb_mon", this);
function void connect_phase (uvm_phase phase);
super.connect_phase (phase);
m_wb_drv.seq_item_port.connect (m_wb_seqr.seq_item_export);
`uvm_info ("wb_AGNT", $sformatf ("Starting %s", this.get_type_name()), UVM_FULL)
//============ spi_agent ===========//
class spi_tx extends uvm_object;
bit [31:0] addr;
bit [31:0] data;
`uvm_object_utils_begin (spi_tx)
function new (string name="spi_tx");
super.new (name);
class spi_driver extends uvm_driver;
`uvm_component_utils (spi_driver)
function new (string name="spi_driver", uvm_component parent);
`uvm_info ("spi_DRV", $sformatf ("Starting %s", this.get_type_name()), UVM_FULL)
class spi_monitor extends uvm_monitor;
`uvm_component_utils (spi_monitor)
function new (string name="spi_monitor", uvm_component parent);
`uvm_info ("spi_MON", $sformatf ("Starting %s", this.get_type_name()), UVM_FULL)
class spi_rw_seq extends uvm_sequence;
`uvm_object_utils (spi_rw_seq)
function new (string name = "spi_rw_seq");
super.new (name);
task body ();
class spi_reset_seq extends uvm_sequence;
`uvm_object_utils (spi_reset_seq)
function new (string name = "spi_reset_seq");
super.new (name);
task body ();
class spi_tx_seq extends uvm_sequence;
`uvm_object_utils (spi_tx_seq)
function new (string name = "spi_tx_seq");
super.new (name);
task body ();
`uvm_info ("tx_SEQ", $sformatf ("Starting %s", this.get_type_name()), UVM_MEDIUM)
class spi_agent extends uvm_agent;
`uvm_component_utils (spi_agent)
spi_driver m_spi_drv;
spi_monitor m_spi_mon;
uvm_sequencer m_spi_seqr;
function new (string name="spi_agent", uvm_component parent);
m_spi_seqr = uvm_sequencer::type_id::create ("m_spi_seqr", this);
m_spi_drv = spi_driver::type_id::create ("m_spi_drv", this);
m_spi_mon = spi_monitor::type_id::create ("m_spi_mon", this);
m_spi_drv.seq_item_port.connect (m_spi_seqr.seq_item_export);
`uvm_info ("spi_AGNT", $sformatf ("Starting %s", this.get_type_name()), UVM_FULL)
//============ apb_agent ===========//
class apb_tx extends uvm_object;
bit [31:0] addr;
bit [31:0] data;
`uvm_object_utils_begin (apb_tx)
function new (string name="apb_tx");
super.new (name);
class apb_driver extends uvm_driver;
`uvm_component_utils (apb_driver)
function new (string name="apb_driver", uvm_component parent);
`uvm_info ("APB_DRV", $sformatf ("Starting %s", this.get_type_name()), UVM_FULL)
class apb_monitor extends uvm_monitor;
`uvm_component_utils (apb_monitor)
function new (string name="apb_monitor", uvm_component parent);
`uvm_info ("APB_MON", $sformatf ("Starting %s", this.get_type_name()), UVM_FULL)
class apb_rw_seq extends uvm_sequence;
`uvm_object_utils (apb_rw_seq)
function new (string name = "apb_rw_seq");
super.new (name);
task body ();
class apb_reset_seq extends uvm_sequence;
`uvm_object_utils (apb_reset_seq)
function new (string name = "apb_reset_seq");
super.new (name);
task body ();
class apb_agent extends uvm_agent;
`uvm_component_utils (apb_agent)
apb_driver m_apb_drv;
apb_monitor m_apb_mon;
uvm_sequencer m_apb_seqr;
function new (string name="apb_agent", uvm_component parent);
m_apb_seqr = uvm_sequencer::type_id::create ("m_apb_seqr", this);
m_apb_drv = apb_driver::type_id::create ("m_apb_drv", this);
m_apb_mon = apb_monitor::type_id::create ("m_apb_mon", this);
m_apb_drv.seq_item_port.connect (m_apb_seqr.seq_item_export);
`uvm_info ("APB_AGNT", $sformatf ("Starting %s", this.get_type_name()), UVM_FULL)
//============ Package ===========//
import uvm_pkg::*;
// This class holds handles to different other sequencers within the environment
class virtual_sequencer extends uvm_sequencer;
`uvm_component_utils (virtual_sequencer)
function new (string name = "virtual_sequencer", uvm_component parent);
uvm_sequencer m_apb_seqr; // APB sequencer handle
uvm_sequencer m_wb_seqr; // WB sequencer handle
uvm_sequencer m_spi_seqr; // SPI sequencer handle
class top_env extends uvm_env;
`uvm_component_utils (top_env)
function new (string name="top_env", uvm_component parent);
apb_agent m_apb_agent;
wb_agent m_wb_agent;
spi_agent m_spi_agent;
virtual_sequencer m_virt_seqr;
m_apb_agent = apb_agent::type_id::create ("m_apb_agent", this);
m_wb_agent = wb_agent::type_id::create ("m_wb_agent", this);
m_spi_agent = spi_agent::type_id::create ("m_spi_agent", this);
m_virt_seqr = virtual_sequencer::type_id::create ("m_virt_seq", this);
// Connect actual agent sequencers with the handles inside virtual sequencer
m_virt_seqr.m_apb_seqr = m_apb_agent.m_apb_seqr;
m_virt_seqr.m_wb_seqr = m_wb_agent.m_wb_seqr;
m_virt_seqr.m_spi_seqr = m_spi_agent.m_spi_seqr;
// This class defines a virtual sequence that creates and starts multiple other
// sequences. Each individual sequence will run on their respective sequencer
// We declare that the virtual sequencer can be accessed in this virtual sequence
// as "p_sequencer" and hence all other sequencers become available to this seq
class virt_seq extends uvm_sequence;
`uvm_object_utils (virt_seq)
`uvm_declare_p_sequencer (virtual_sequencer)
apb_rw_seq m_apb_rw_seq;
wb_reset_seq m_wb_reset_seq;
spi_tx_seq m_spi_tx_seq;
function new (string name = "virt_seq");
super.new (name);
virtual task body ();
m_apb_rw_seq = apb_rw_seq::type_id::create ("m_apb_rw_seq");
m_wb_reset_seq = wb_reset_seq::type_id::create ("m_wb_reset_seq");
m_spi_tx_seq = spi_tx_seq::type_id::create ("m_spi_tx_seq");
`uvm_info ("VSEQ", "Start of virtual sequence", UVM_MEDIUM)
m_wb_reset_seq.start (p_sequencer.m_wb_seqr);
#20 m_apb_rw_seq.start (p_sequencer.m_apb_seqr);
join
#10;
m_spi_tx_seq.start (p_sequencer.m_spi_seqr);
`uvm_info ("VSEQ", "End of virtual sequence", UVM_MEDIUM)
// A simple test to start our virtual sequence
class base_test extends uvm_test;
`uvm_component_utils (base_test)
top_env m_top_env;
virt_seq m_virt_seq;
function new (string name, uvm_component parent = null);
endfunction : new
virtual function void build_phase (uvm_phase phase);
m_top_env = top_env::type_id::create ("m_top_env", this);
m_virt_seq = virt_seq::type_id::create ("m_virt_seq");
virtual function void end_of_elaboration_phase (uvm_phase phase);
uvm_top.print_topology ();
super.main_phase (phase);
phase.raise_objection (this);
m_virt_seq.start (m_top_env.m_virt_seqr);
phase.drop_objection (this);
virtual task shutdown_phase (uvm_phase phase);
super.shutdown_phase (phase);
`uvm_info ("SHUT", "Shutting down test ...", UVM_MEDIUM)
//============ top_level ===========//
`timescale 1ns/1ps
import uvm_pkg::*;
module tb_top;
run_test ("base_test");
//=================== END ===================//
