Variable type is not user defined type
For below code snippet seeing compilation issue saying variable type is not user defined type
Error-[SE] Syntax error
path_to_error.env.svh
token is ‘Reg_h’
rand reg1 Reg_h;
file name: reg_file.svh
class reg1 extends base_reg
//other tasks//
file name: env.svh
`include "reg_file.svh"
class env extends base_env
rand reg1 Reg_h;
//some tasks//
package pkg;
`include "env.svh"
endpackage
In reply to Swetha E:
Where is class reg1 defined? It probably needs to be in a package that gets imported into pkg.
See SystemVerilog Coding Guidelines: Package import versus `include - Verification Horizons
class reg1 is defined inside file reg_file.svh which is included in env.svh.
And file reg_file.svh is getting compiled. But the class reg1 inside reg_file.svh is not able to find it.
The code you have shown is missing semicolons, but there are probably other problems with the code you have not shown.
Start with these simple guidelines. They may not
  • Put every class in a separate file, like reg1.svh and env.svh
  • Include each of these in a package, grouping together all definitions for a single protocol, such as axi_pkg.sv
  • Start the package with importing the UVM package and macros
  • Don’t include files / classes anywhere else
  • Compile the package
  • Import the package in other packages, or into your top test module with: import axi_pkg::*;
These won’t solve all issues, but they do help you get organized.
