How can I make a read-only variable?
I want this variable to be writeable inside a class but I want it to be read-only when accessed outside the class. Local and protected type of encapsulation is not readable when accessed outside the class. Instance constant data type can be readable outside the class but changing the value of this variable is only possible during class construction. I don’t want that because all my class variables will reset to its default values when the class is constructed again.
So, is there a way to make a variable that can be accessed inside the class but becomes read-only outside the class?
class v;
protected int name=56;
function int get_var ();
return name;
module p;
v myc = new();
$display("Variable with class funct: %0d",myc.get_var());
// Error-[SV-ICVA] Illegal class variable access
// $display("Variable with class funct: %0d",myc.name);
The way to do this it to write class accessors methods.
Is the above code what you meant about accessors methods in Java?
