Valueplusargs on parameter in SystemVerilog
Hello,
I have a PLL Model in Verilog which has
parameter base_frequency = 1.5 ( 1.5 GHz )
parameter step_size = 0.040 ( 40 MHz )
Is it possible to use $valueplusargs and pass command line values and change the
paramter. I need to have different base frequency values and different step size values to be
passed
run_command +base_freq=1.7 +step_size=0.050
JeffD
In reply to dvuvmsv:
Hello,
passed
JeffD
We cannot change the verilog parameter in run-time simulation using $value$plusargs.
The parameter is constant and only can be assigned in compile-time with default value, or elaboration-time with overriden value
Hello,
passed
JeffD
No, you can’t change the parameter at run time.
isn’t it possible for you to use the variable instead of parameter and then use the $valueplusargs?
Hi Chris and Rahul,
Thanks for your reply. Instead of parameter what variable can I use ?
I need values like 1.5, 1.6, 1.7 … I cannot use integer. Which datatype
can I use instead of parameter ?
JeffD
Hi Chris and Rahul,
JeffD
‘real’ or ‘shortreal’ should be OK.
  real step_size = 0.040;
    if($value$plusargs("step_size=%f", step_size)) begin
      $display("step_size = %f", step_size);
