Hi All,
Please guide how to pass $value$plusarg value in assertion file.
Hi All,
In reply to ajp0:
This is a very open-ended question. You can use $value$plusargs to initialize any variable, and you use variables in assertions. Did you have something in mind?
When I am using plusarg value in assertion,
int k=0;
if(($value$plusargs(“NUM=%0d”, k)))
$rose((enable)[->k]);
Error: Expression k . I should use constant expression
The plusarg value is passed through run command line
In reply to ajp0:
You are using a variable where a constant expression is required. Assertions get synthesized at compile time, and certain constructs like replication need to be fixed. It’s too late to change the value at run time.
Your options are to change the plusarg to a +define at compile time, then use [->`NUM] in your assertion, or change your assertion code to use a different set of constructs.
Regarding $rose((enable)[->k]); // k is a variable, consider using my package to handle dynamic repeats and delays.
https://verificationacademy.com/forums/systemverilog/sva-package-dynamic-and-range-delays-and-repeats
bit clk, a, b;
int k=2;
// sequence definition from the package
sequence q_dynamic_repeat(q_s, count);
int v=count;
(1, v=count) ##0 first_match((q_s, v=v-1'b1) [*1:$] ##0 v<=0);
endsequence
ap_dyn: assert property(@ (posedge clk) a |=> q_dynamic_repeat($rose(b)[->1], k) );
Thanks Ben and Dave for the inputs
