integer da4[];
da4='{1,2,3,4};
$display("da4=%p",da4);
Result: da4='{1,2,3,4};
Doubt: Can we assign value in Dynamic array without using new();
integer da4[];
da4='{1,2,3,4};
In reply to Kj@2199:
From the LRM section 7.5 Dynamic arrays:
The size of a dynamic array is set by the new constructor or array assignment, described in 7.5.1 and 7.6 respectively.
So the answer to your question is yes, you can assign a value to a dynamic array without using new().
In reply to cgales:
Thank you for the clarification.
