Hello,
I have this error but i don’t know where i have the problem :
test_spi_2_ahb [CLDEXT] Cannot set ‘test_spi_2_ahb’ as a child of ‘uvm_test_top’, which already has a child by that name*__*
this is my code :
class e_test extends uvm_test ;
`uvm_component_utils(e_test)
spi2ahb_test test_spi_2_ahb ;
// function new
function new (input string name, uvm_component parent = null) ;
super.new (name,parent) ;
endfunction : new
// build_phase : Création de la classe spi2ahb
super.build_phase(phase);
test_spi_2_ahb = spi2ahb_test::type_id::create("test_spi_2_ahb",this);
endfunction : build_phase
endclass : e_test
class test extends uve_test;
`uvm_component_utils(test)
function new ( input string name, input uvm_component parent = null ) ;
super . new ( name, parent ) ;
// u_test = uve_test::type_id::create("u_test",this);
// Main test sequence
virtual task main_phase ( uvm_phase phase ) ;
logic [`DIVE_SPI_DATA_WIDTH - 1 : 0] data;
logic [`DIVE_SPI_DATA_WIDTH - 1 : 0] rdata[];
logic [`DIVE_SPI_DATA_WIDTH - 1 : 0] wdata[];
integer def_nb_data_access;
integer def_start_addr;
byte shift = $clog2(`DIVE_SPI_DATA_WIDTH/8);
phase . raise_objection ( .obj ( this ) ) ;
def_start_addr = 0;
def_nb_data_access = 1; //TODO_RNK return to 20
test_spi_2_ahb.spi_write_reg_spi_mode(TB_CICR__ADDRESS , QUAD);
test_spi_2_ahb.spi_checksum_compare();
end class
spi_checksum_compare(),spi_write_reg_spi_mode : are methods declared on class spi2ahb_test
