UVM
In reply to Muthamizh:
I think you have seen in is 0 from the beginning and out and state is x. This comes from your design.Simple Verilog does not know 2-state variables. There is the type reg used.
Yes in is 0 from the beginning. Thank you so much for your suggestions. They were very helpful and useful. Thanks again.
What is phase objection actually?
What do you mean with phase objection?
The objection mechanism is used stop the simulation after completing all sequences and run_phase tasks.
If you do not implement this mechanism the simulation stucks at time 0.
You can implement the objections in different objects (components, sequences).
This is what i wanted to know. Thank you for the explanation.
Now i need to do another testcase for the same fsm. i need to stop the clock generation and check the response. How to do that? Any idea please?
how to disable clock generation in between, which is being generated from top module? Please help me out.
You can implement a signal (clock_dis signal) in your module interface, this signal can be driven by your uvm_driver. Use this signal to mask the clock signal in top/interface where your clock is generated.
UVM driver takes config/seq_item’s attribute to control clock_dis signal.
Please visit this thread, it may help you implement the idea:
https://verificationacademy.com/forums/uvm/clock-generator
You can try it while waiting for someone else to provide better solution.
In reply to chris_le:
Thank you so much for your suggestion.
There is no frequency specifications for my fsm rtl. So how to calculate the frequency with clock generated?
What is IP level verification? i searched for the abbrevation of IP. But I dint find it anywhere. Could you please explain IP level verification?
You have much learning to do. First start by improving your search skills:
http://lmgtfy.com/?q=IP+level+verification
First two hits explain Verification IP.
