Hi all,
any one can you give example for uvm_max_quit_count?
Hi all,
UVM_MAX_QUIT_COUNT is an argument you can pass to the UVM command line processor.
The syntax is
+UVM_MAX_QUIT_COUNT=
+UVM_MAX_QUIT_COUNT=5 menas the simulation will stop after 5 errors.
Hi chr_sue
my code given below
report.sv
class rept extends uvm_component;
virtual intf vif;
`uvm_component_utils(rept)
tx tx1;
function new(string name,uvm_component parent);
super.new(name,parent);
tx1=tx::type_id::create("tx1",this);
if (!uvm_config_db#(virtual intf)::get(this,"","intf",vif)) begin
`uvm_error(get_full_name(),"interface handle is not in config_db");
$display("REPOTER");
task run();
uvm_report_info(get_full_name(),"Info Message : adcd1,run_phase,",UVM_NONE,`__FILE__,`__LINE__);
uvm_report_info(get_full_name(),"Info Message : adcd2,run_phase,",UVM_LOW,`__FILE__,`__LINE__);
uvm_report_info(get_full_name(),"Info Message : adcd3,run_phase,",UVM_MEDIUM,`__FILE__,`__LINE__);
uvm_report_info(get_full_name(),"Info Message : adcd4,run_phase,",UVM_HIGH,`__FILE__,`__LINE__);
uvm_report_error(get_full_name(),"Info Message : adcd5,run_phase,",UVM_HIGH,`__FILE__,`__LINE__);
uvm_report_error(get_full_name(),"Info Message : adcd6,run_phase,",UVM_HIGH,`__FILE__,`__LINE__);
uvm_report_error(get_full_name(),"Info Message : adcd7,run_phase,",UVM_HIGH,`__FILE__,`__LINE__);
uvm_report_warning(get_full_name(),"Info Message : adcd8,run_phase,",UVM_NONE,`__FILE__,`__LINE__);
uvm_report_error(get_full_name(),"Info Message : adcd9,run_phase,",UVM_LOW,`__FILE__,`__LINE__);
uvm_report_fatal(get_full_name(),"Info Message : adcd10,run_phase,",UVM_MEDIUM,`__FILE__,`__LINE__);
uvm_report_warning(get_full_name(),"Info Message : adcd11,run_phase,",UVM_HIGH,`__FILE__,`__LINE__);
//set_quit_count(int quit_count);
uvm_config_db#(int)::get(this,"", "count", tx1.count);
uvm_config_db#(int)::get(this,"r2", "count", tx1.count);
//$display("count=%d",tx1.count);
tx1.print();
top.sv
`include"uvm_pkg.sv"
import uvm_pkg::*;
`include"tx.sv"
`include"intf.sv"
`include"report.sv"
//int file;
UVM_FILE file;
rept r1;
rept r2;
rept r3;
rept r4;
tx tx1;
intf pif();
r1=new("r1",null);
r2=new("r2",null);
r3=new("r3",null);
r4=new("r4",null);
int UVM_MAX_COUNT=6;
file=$fopen("log_info9.log","w");
//fh=$fopen("log_info1.txt","w");
$fwrite(file);
uvm_config_db#(virtual intf)::set(uvm_root::get(),"*","intf",pif);
r1.set_report_verbosity_level(UVM_MEDIUM);
r2.set_report_verbosity_level(UVM_LOW);
r3.set_report_verbosity_level(UVM_NONE);
r4.set_report_verbosity_level(UVM_HIGH);
uvm_config_db#(int)::set(null,"*" , "count" ,10);
uvm_config_db#(int)::set(null,"r2*" , "count" ,20);
r1.set_report_default_file_hier (file);
r1.set_report_severity_action(UVM_INFO, UVM_DISPLAY+UVM_LOG+UVM_COUNT);
r2.set_report_default_file_hier (file);
r2.set_report_severity_action(UVM_INFO, UVM_DISPLAY+UVM_LOG);
r3.set_report_default_file_hier (file);
r3.set_report_severity_action(UVM_INFO, UVM_DISPLAY+UVM_LOG);
r4.set_report_default_file_hier (file);
r4.set_report_severity_action(UVM_INFO, UVM_DISPLAY+UVM_LOG);
// r1.set_report_severity_action(UVM_INFO,UVM_NO_ACTION|UVM_EXIT);//done
// r2.set_report_severity_action(UVM_INFO,UVM_NO_ACTION|UVM_EXIT);//done
// r2.set_report_severity_action(UVM_INFO,UVM_EXIT|UVM_COUNT);
//r4.set_report_severity_action(UVM_ERROR, UVM_EXIT|UVM_LOG|UVM_COUNT);
// r4.set_report_severity_action(UVM_ERROR, UVM_MAX_COUNT|UVM_EXIT);
// r4.get_quit_count(UVM_ERROR, UVM_MAX_COUNT|UVM_EXIT);
//r4.set_report_severity_action(UVM_INFO, UVM_STOP|UVM_LOG);
// r4.set_report_severity_action(UVM_DISPLAY, UVM_STOP|UVM_LOG);
run_test();
// $fclose(fh);
//tx1.print();
intf.sv
interface intf;
endinterface
tx.sv
class tx extends uvm_sequence_item;
int count=30;
`uvm_object_utils_begin(tx)
`uvm_field_int(count,UVM_ALL_ON|UVM_NOPACK)
`uvm_object_utils_end
if i am setting +UVM_MAX_QUIT_COUNT=1 means i am getting below output.
UVM_INFO @ 0: reporter [RNTST] Running test …
so output is correct or not?
please tell me. i am learning UVM myself so i cont understand easily.
In reply to yuvi66:
To be honest, what yo are presenting here is not a UVM testbench. It is a SV testbench using UVM constructs.
The key thing is a test is missing.
Your code is even not compiling in my environment.
How do you invoke your simulator and with which arguments?
Hi chr_sue,
I will correct mistakes. can you give example coding for severity?
Thank you
In reply to yuvi66:
Please read this article form the UVM Cookbook:
https://verificationacademy.com/cookbook/reporting/verbosity
At the bottom you’ll find a code example.
