there’s a design whose top level is system verilog with some nested VHDL unit.
I’m able to deposit values (uvm_hdl_deposit) into VHDL signals if I specify the entire vhdl signal name. I cannot deposit a value into a single bit of the signal.
Is it possible to force or deposit a single bit of a VHDL path?
Furthermore, I tried to use uvm_hdl_check_path. Apparently the command is not recognized.
In general, in case of VHDL, should uvm_hdl_deposit be used in place of umv_hdl_force?
Kind Regards,
Fabio
