Using system verilog que can we implement fifo?
using system verilog que can we implement fifo?
In reply to lalithjithan:
Below is a model from my SVA Handbook 4th Edition
// Data queue for verification.
// Queue, maximum size is 2**BIT_DEPTH
word_t dataQ [$:2**BIT_DEPTH-1];
// Data read from queue
word_t data_fromQ;
// Push and Pop tasks
task pop_task;
    data_in <= 'X; // unsized Xs
    pop <= 1'b1;
    data_fromQ <= dataQ.pop_front();
    @ (posedge clk);
endtask : pop_task
task push_task (word_t data);
    $display ("%0t %m Push data %0h ", $time, data);
    data_in <= data; //data to be written
    push <= 1'b1;
    dataQ.push_back(data); // push to dataQ
    @ (posedge clk);
endtask : push_task
task idle_task(int num_idle_cyles);
    push <= 1’b0;
    pop <= 1’b0;
    data_in <= ‘X;
    assert (num_idle_cycles < 10000) else
     $warning (“%0t %0m idle_task is invoked with LARGE number of idle cycles %0d “,
        num_idle_cycles);
    repeat (num_idle_cycles) @ (posedge clk);
endtask : idle_task
In 2012 systemverilog LRM, there is an example for FIFO and Stack as below in 8.26 interface class chapter.
interface class PutImp#(type PUT_T = logic);
  pure virtual function void put(PUT_T a);
interface class GetImp#(type GET_T = logic);
  pure virtual function GET_T get();
class Fifo#(type T = logic, int DEPTH=1) implements PutImp#(T), GetImp#(T);
  T myFifo [$:DEPTH-1];
  virtual function void put(T a);
    myFifo.push_back(a);
  virtual function T get();
    get = myFifo.pop_front();
class Stack#(type T = logic, int DEPTH=1) implements PutImp#(T), GetImp#(T);
    myFifo.push_front(a);
Thankyou Ben & Lina
