While revisiting my verilog slides I came across an example :
`timescale 10 ns / 1 ns
module time_test;
integer a=0, b=0, c=0;
#1.53 a=6; $display($realtime,," a == 6 @ T == %0t ",$realtime );
#2.56 b=9; $display($realtime,," b == 9 @ T == %0t ",$realtime );
#1.547 c=4; $display($realtime,," c == 4 @ T == %0t ",$realtime );
Based on timeprecision the delays are rounded off to 1 decimal place . #1.53 would be #1.5 , #2.56 would be #2.6 and #1.547 would be #1.5 .
Without using %t , $realtime would return the same rounded-off real numbers : 1.5 , 4.1 and 5.6
(a) However when I use %t along with $realtime , why do we observe 15 , 41 and 56 in the result ?
Then I replaced $realtime with $time in the above example :
Without using %t , $time would return an integer after rounding off : 2 , 4 and 6
(b) But when I use %t , I observe 20 , 40 and 60 in the result
One intuition I have is that format specification %t displays simulation time.
$realtime returns a real number scaled to time unit of 10ns .
Hence simulation time would be obtained my multiplying these real values ( i.e the argument $realtime ) by time unit of 10ns
Therefore we observe 15 , 41 and 56 ( which are actually in units of “ns” )
Similarly for $time we simply multiply the time unit of 10ns to the integer value returned by $time .
Hence we observe 20 , 40 and 60 ( which are again in units of “ns” )
NOTE : These values returned by $time are different than the actual simulation time at which the assignments occur .
Is my initial thought process correct ? Please correct me if wrong .
Thanks .
