Using sum() to Calculate the Sum of a 2D Array
I’d like to know how to calculate the sum of a 2d array using sum() method, or any other more efficient methods.
According to the RFM 2017 7.12.3 Array reduction methods, the second example:
logic [7:0] m [2][2] = '{ '{5, 10}, '{15, 20} };
int y;
y = m.sum with (item.sum with (item)); // y becomes 50 => 5+10+15+20
I should be able to get the sum-product this way. However, I was not able to compile my code using Incisive and QuestaSim. Does anyone know what went wrong?
Thanks!
In reply to amy992:
Please show a complete example.
Basically I just put everything there into a module
module array_2d_sum;
  int y;
    $display("m is %p", m);
The compilation error in QuestaSim is Error: vlog-13069, pointing to this line y = m.sum with (item.sum with (item)); near “=”: syntax error, unexpected ‘=’.
The same line has another error message: vlog-13205, Syntax error found in the scope following ‘y’. Is there a missing ‘::’?
In reply to amy992:
The assignment to y needs to go inside the initial begin/end block. There is nothing wrong with the use of the sum() method.
I see. Thanks.
I was not able to put this into a constraint. Something like this:
rand int A[2][2];
constraint c1{
  (A.sum with (item.sum with (item))) == 0;
The code wouldn’t compile. Can you point out where I did wrong here?
In reply to amy992:
please see How to create a Minimal, Reproducible Example - Help Center - Stack Overflow
Basically, I would like to know how to put a constraint on the sum of a 2d array.
module p1;
  class c1;
    rand int m [2][2];
    rand int x;
    constraint c1{
      foreach(m[i,j])
        m[i][j] inside {[-1:1]};
    constraint c1_2{
      x == m.sum with (item.sum with (item));
      //only works in in vcs
      //x == m.sum();
    constraint c1_3{
      x == 2;
  c1 c1_h;
  logic [7:0] n [2][2] = '{ '{5, 10}, '{15, 20} };
  int n_sum;
    c1_h = new();
    if(c1_h.randomize())
      $display("m is %p", c1_h.m);
    n_sum = n.sum with (item.sum with (item));
    //the sum of 2d array can be calculated this way
    $display("n_sum is %d", n_sum);
I am wondering why my code doesn’t work? Is there a more convenient way to put a constraint on the sum of a 2d array?
Thank you.
In reply to amy992:
You need to explain what “doesn’t work” means. When I run this, I get
# m is '{'{1, 1}, '{1, -1}}
# n_sum is          50
In reply to amy992:
# n_sum is          50
I meant the constraint c1_2 cannot be satisfied using Incisive or VCS.
Basically what I would like to do is to put a constraint on the sum of a 2D array. Not sure what’s the best way to construct the constraint.
In reply to amy992:
The expression in your constraint is taken straight from the LRM section you mention. If your tool has a problem with it, you’ll have to take it up with your tool vendor. This Mentor sponsored public forum is not for discussing tool specific issues.
Hi All,
I need to find the sum in a 2D array. This is what I have tried, but not able to get the desired output. Could someone suggest?
module p1;
  class c1;
    rand bit [3:0] addr[2][2];
   constraint c1{
     addr.sum() with (item.sum())==8;
    $display("elements %0p", obj);
  c1 obj;
    obj = new;
    repeat (4)
    obj.randomize();
//OUTUPT
> run
elements '{addr:'{'{'h7, 'ha}, '{'ha, 'hd}}}
elements '{addr:'{'{'h9, 'ha}, '{'ha, 'hb}}}
elements '{addr:'{'{'h9, 'h4}, '{'hb, 'h0}}}
elements '{addr:'{'{'h6, 'h9}, '{'hd, 'hc}}}
Sum of array elements is not equal to 8.
Which are the elements to add here and how to get the sum exactly as 8
Thank you?
