Hi Dave,
Basically, I would like to know how to put a constraint on the sum of a 2d array.
module p1;
class c1;
rand int m [2][2];
rand int x;
constraint c1{
foreach(m[i,j])
m[i][j] inside {[-1:1]};
constraint c1_2{
x == m.sum with (item.sum with (item));
//only works in in vcs
//x == m.sum();
constraint c1_3{
x == 2;
c1 c1_h;
logic [7:0] n [2][2] = '{ '{5, 10}, '{15, 20} };
int n_sum;
c1_h = new();
if(c1_h.randomize())
$display("m is %p", c1_h.m);
n_sum = n.sum with (item.sum with (item));
//the sum of 2d array can be calculated this way
$display("n_sum is %d", n_sum);
I am wondering why my code doesn’t work? Is there a more convenient way to put a constraint on the sum of a 2d array?
Thank you.
