Using $past for range of cycles
Hello,
I am trying to write a assertion for the below scenario.
A box has 4 inputs (a,b,c,d) and a single output (ack). We need to write an assertion to make sure when output (ack) is asserted, a and b and c and d should have asserted (in any order) in the last 4 cycles.
Below is my try: I want to specify the range in the $past, can someone review the code and let me know?
module tb;
  bit clk,ack;
  bit req[4];
   default clocking @(posedge clk);
     endclocking
     initial forever #10 clk=!clk;
  bit was_a_req, was_b_req,was_c_req,was_d_req;
     always  @(posedge clk) begin
       if(was_a_req)  req[0] <= 1'b1;
       if(was_b_req)  req[1]  <= 1'b1;
       if (was_c_req) req[2] <= 1'b1;
       if (was_d_req) req[3] <=1;
       ap_valid_req: assert property(@ (posedge clk)
                                     $rose(ack) |-> $past((req[3] & req[2] & req[1] & req [0]),4)) $display ("Assertion passed",$time);
              $dumpfile ("hello.vcd");
           $dumpvars (0,tb);
        repeat(200) begin
          repeat(1) @(posedge clk)#1;
          if (!randomize(was_a_req,was_b_req,was_c_req,was_d_req,ack) with
             { was_a_req dist { 1'b1:=1,1'b0:=1};
               was_b_req dist { 1'b1:=1,1'b0:=1};
               was_c_req dist { 1'b1:=1,1'b0:=1};
               was_d_req dist { 1'b1:=1,1'b0:=1};
               ack dist { 1'b1:=1,1'b0:=1};
              }) `uvm_error("MYERR", "This is a randomize error");
        $stop;
In reply to rag123:
You need to consider the best structure for your support logic.
In this case, to test for a a past of a, b, c, d, you can use a 4-bit shift register where at every clock you do a shift-right with the input=OR(a, b, c, d). Thus,
 bit a, b, c, d;
  bit[3:0] was_abcd;  // the shift reg
        if(a || b || c || d) was_abcd <= {1'b1, was_abcd[3:1]};
        else was_abcd <= {1'b0, was_abcd[3:1]};
                     $rose(ack) |-> was_abcd >= 1) $display ("Assertion passed",$time);
The testbench, modify as needed.
/ A box has 4 inputs (a,b,c,d) and a single output (ack).
// We need to write an assertion to make sure when output (ack) is asserted,
// a and b and c and d should have asserted (in any order) in the last 4 cycles. w?
module tb;
    `include "uvm_macros.svh"
    import uvm_pkg::*;
  bit clk,ack;
  bit a, b, c, d;
  bit[3:0] was_abcd;
     endclocking
           $dumpvars (0,tb);
        repeat(200) begin
          if (!randomize(a, b,c, d, ack)
        $stop;
  3. Papers:
//untested
//Pipelining may solve but may not be the best solution
//algorithm:
//in past 4 cycles at least once the a && b && c && d should be 1 to satisfy your problem //statement.
reg [3:0]pipe1;
reg [3:0]pipe2;
reg [3:0]pipe3;
reg [3:0]pipe4;
always @posedge clk begin
if(rst) begin
pipe1 <= 0;
pipe2 <= 0;
pipe3 <= 0;
pipe4 <= 0;
end else begin
pipe1 <= {a,b,c,d};
pipe2 <= pipe1;
pipe3 <= pipe2;
pipe4 <= pipe3;
property p_ack_check;
((pipe1[0] | pipe2[0] | pipe3[0] | pipe4[0]) &&
(pipe1[1] | pipe2[1] | pipe3[1] | pipe4[1]) &&
(pipe1[2] | pipe2[2] | pipe3[2] | pipe4[2]) &&
(pipe1[3] | pipe2[3] | pipe3[3] | pipe4[3])) |-> (ack == 1);
assert_abcd: assert property @posedge(clk) disable_iff rst p_ack_check;
