I have a set of parameters, and wish to construct parameterized objects using these parameters. Ideally the following code should work:
class B;
virtual function void who();
class C#(int p) extends B;
$display("I am C#(%0d)",p);
module m;
parameter N=3;
parameter integer len[N]={5,6,7};
B c_array[3];
for(int i=0;i<N;i++) begin
C#(len[i]) myC=new;
c_array[i]=myC;
myC.who();
This complains i is not a compile time constant.
Any other way of achieving the same result? My goal is to write generic code that works for any given parameters.
The following works, but is hard to maintain if someone uses a parameter that hasn’t been used before:
module m;
parameter N=3;
B c_array[3];
case(len[i])
5: begin
C#(5) myC=new;
c_array[i]=myC;
6: begin
C#(6) myC=new;
c_array[i]=myC;
7: begin
C#(7) myC=new;
c_array[i]=myC;
endcase
c_array[i].who();
module m;
parameter N=3;
B c_array[3];
for(genvar i=0;i<N;i++) begin
automatic C#(len[i]) myC=new;
c_array[i]=myC;
myC.who();
One problem you may encounter is that if another initial block needs to read c_array at time 0, you have a race condition. A way of removing that race is to make the c_array initialization happen before time 0 as a static initialization:
virtual class B; // made virtual so that no one is allowed to construct it
pure virtual function void who();
static B c_array[$];
function new();
c_array.push_back(this);
module m;
parameter N=3;
C#(len[i]) myC=new;
initial
foreach (B::c_array[i]) B::c_array[i].who();
Thanks for the generate suggestion. I assume the race condition you mentioned isn’t really related to this? I could/would have the same issue with my case statement solution?
Now the real problem is that the objects I want to create are UVM agents inside a UVM env. I think the generate wont work there? I assume I could create the agents just like the interfaces on the ‘static module’ side of the testbench and pass handles in the config db. But this kind of (further) breaks the top-down UVM construction like it is the case with the interfaces.
In reply to NiLu:
Yes, the race conditional is another issue whenever you have multiple initial blocks reading and writing the same variables at time 0.
You are also correct that you can’t use a generate block inside a class. But what you can do instead of constructing an array of agents inside the generate block, you use the factory to construct an array of proxies for the agent using uvm_object wrapper. It would look something like
package my_stuff;
class my_agent#(int p) extends uvm_agent;
uvm_object_wrapper c_array[int];
class C#(int p) extends uvm_component_registry#(my_agent#(p));
function new;
c_array[p] = this;
endpackage
parameter N=3;
my_stuff::C#(len[i]) myC=new;
initial run_test();
Then when you go to construct your agents in the env, you can do this with i as a variable
In reply to NiLu:
It should work if some of the parameters are equal. One of the benefits of using a proxy classes is they are lightweight stand-ins for the actual class. It doesn’t matter that you will create some of these classes multiple times - they will just get thrown away when they get assigned to the same element in the associative array.
