Using file operation in verilog can we read the input from txt file or not, if yes then how?
using file operation in verilog can we read the input from txt file or not, if yes then how?
i am trying with mux 4x1 but not getting output file and not even read the input txt file…
module mux41_filerw_tb();
  reg [1:0]sel;
  reg [3:0]a;
  wire y ;
  reg [0:7]mem[0:7];
integer i,j;
  task initialize;
       a=0;
       sel=0;
task select(input [1:0]a);
	sel=a;
initial
 $readmemb("mux.txt");
 outfile=$fopen("write.txt");
	initialize;
	#10;
	for(i=0;i<4;i=i+1)
	    select(i);
		for(j=0;j<16;j=j+1)
		    inps(j);
		    #10;
			$fdisplay(outfile,"a[3:0]=%b--select=%b--y=%d\n", a, sel, y);
	$fclose(outfile);
	#100;
    $stop;
In reply to Lavin786:
If you post what you have already written and what problems you are having, someone may be able to give you some advice.
In reply to cgales:
yup check updated one
I ran your code with no issues. The output file ‘write.txt’ was generated and had the expected entries:
a[3:0]=0000–select=00–y=0
a[3:0]=0001–select=00–y=0
a[3:0]=0010–select=00–y=0
a[3:0]=0011–select=00–y=0
Perhaps you are having a tool specific issue. If so, you will need to contact your tool vendor for support.
In reply to cgales:
okay and what about input file
Yes, the input file was loaded into the memory array.
