I am trying to use a Macro to assign signals based upon certain values as passed to Macro, but run into errors. This is an example code.
I have tried using generate / gevar within macro, but same error. It works without if statement, but doesn’t solve the intent.
`define LBsig_IF(i) \
begin \
if(i == 1) \
assign sig_``i``_ip = if_sig[``i``+1]; \
else if(i == 3) \
assign sig_``i``_ip = if_sig[``i``+2]; \
end \
module test;
int sig_1_ip, sig_2_ip, sig_3_ip;
int if_sig[10];
`LBsig_IF(1)
if_sig[0] = 1;
if_sig[1] = 1;
if_sig[2] = 1;
if_sig[3] = 1;
if_sig[4] = 1;
Error:**
Error-[SE] Syntax error
“test.v”, 20: token is ‘assign’
assign sig_i_ip = if_sig[i+1];
