I want to generate a random 64 bit number which is something like this,
Little-Endian encoded 64 bit unsigned integer with eight implied decimal places
If I use
rand [63:0] abc;
what will be my constraint to restrict legal values?
If I use
rand [63:0] abc;
In reply to vg_ql:
you can not use rand without specifiying data type.
rand bit[63:0] abc ; // unsigned 64 bit value
Can you please explain more about your legal constraint range ?
In reply to vg_ql:
SystemVerilog only has the capability to generate random integers. So you might have to generate a 64-bit integer and divide it by 108. But representing a fixed point number in a language that only supports integer and real types is another topic.
Thank you Dave.
