I got the error while the run design in tb.sv file.
// File name : tb.sv
In this class we are connected the all passive mode uvc’s.
So for debugging here i was called the ‘debug_connected_to’ function. To know the TLM port connection.
function void end_of_elaboration();
uvm_report_info(get_full_name(),“End_of_elaboration of *** MASTER”, UVM_LOW);
debug_connected_to (); // How to call this function?
For single port/export/imps connection check, this method will be used.
Usage :
port_name.debug_connected_to() for the port fanout network.
port_name.debug_provided_to() for the port_fanin network.
Note : if your are trying to print all the port/export connections without specific, this will not work.
