Understanding the performance impact of SVA construct
Requirement -
RTL.sb shouldn’t change between cond_a and cond_b.
Though there are multiple ways to write assertion for this requirement, I have chosen below one.
Can someone please help me understand the performance impact of this style of coding (mainly due to the use of [*0:$])?
Is it good/bad?
 property p_sb_check;
      logic [5:0] temp_sb;
      @(posedge clk) disable iff (reset)
      (cond_a, temp_sb = RTL.sb) |-> (temp_sb === RTL.sb) [*0:$] ##1 cond_b ##0 (temp_sb === RTL.sb) ;
Thanks in advance.
PS: I have not used $rose in the antecedent because till cond_b becomes true, cond_a will never trigger and also cond_a is 1 clock pulse. (There are separate checks for all these)
In reply to naveensv:
Looks OK to me. You may want to qualify the consequent as “strong”.
Ben systemverilog.us
You can also write this as
      cond_a |=> $stable(RTL.sb) until_with cond_b;
There is a saying “All roads lead to Rome!”
Your assertion is OK. Is Dave’s approach better? The way I see it, it really does not matter. Yours (and generally my style) is more waveform-like in defining the requirements. Dave’s is more English, higher-level definition; however, it requires some mental exercises to convert the stable until_with to its meaning.
Addressing your concern *"the performance impact of this style of coding (mainly due to the use of [0:$])? Is it good/bad?".
I don’t believe that this is a concern. I am not a simulator builder, thus, I don’t know the implementation. However, In my paper SVA Alternative for Complex Assertions
Verification Horizons - March 2018 Issue | Verification Academy
I demonstrate a model for the assertions. Your model is of the form:
 (a, v = c) |-> (v === c) [*0:$] ##1 b ##0 (v === c) ;
// Using task triggered with a fork join_none, it looks like this
// Note the while loop that represents the [*0:$]
//  I don't see a heavy load or complexity here, though the consequent is multithreaded
task automatic t_b();
        //  (a, v = c) |-> (v === c) [*0:$] ##1 b ##0 (v === c) ;
        logic [5:0] v;
        if(a) v=c;
        else return;  // (a, v = c) |->
        while (b==1'b0) begin
            v_eql_c_till_b: assert(v === c); // (v === c) [*0:$] ##1 b
            if(v != c) begin
                -> e_fail;
                return;
            else -> e_pass;// for debug
            @(posedge clk);
        // b==1'b1
        v_eql_c_at_b: assert (v === c); // ##0 (v === c) ;
        if(v != c) -> e_fail; else -> e_pass;// for debug
    endtask : t_b
// This is the testbench
    bit clk, a, b, reset=0;
    logic [5:0] c=6'b100001;
    event e_pass, e_fail;  // for debug
    event e_delay;
    let tID="My model";
    initial forever #10 clk=!clk;
        logic [5:0] v;
    ap_sb_check : assert property(p_sb_check);
    // Action block is not used here
    //  t_b(i, last_range, failing, done);
        logic [5:0] v;
        if(a) v=c;
            if(v != c) begin
                -> e_fail;
                return;
            @(posedge clk);
        // b==1'b1
    endtask : t_b
    always  @(posedge clk)  begin // emulate the assertion firing
            t_b();  // Assertion for the above property emulated with a task
            // .. other tasks representing properties
        join_none
        repeat(200) begin
            repeat(1) @(posedge clk); #2;
            if (!randomize(a, b, c)  with
            { c dist {6'b100000:=1, 6'b011111:=1};
        }) `uvm_error("MYERR", "This is a randomize error");
    $finish;
  2. SVA: Package for dynamic and range delays and repeats | Verification Academy
Thank you both :)
shouldn’t it be
      cond_a |-> $stable(RTL.sb) until_with cond_b;
