Hello,
I am having issues to view waveform for the UVM code that I wrote. I am using a .do file to compile and simulate the files. Below is the error that I am receiving:
** Error: (vish-4014) No objects found matching ‘*’.
Error in macro ./run.do line 11
while executing
“add wave -r *”
I am getting this error only when I am executing my adder design using the sample UVM TB that I wrote. I am able to view the waveform fine with the sample conventional TB without any class or UVM syntax.
I have attached all the files to this message. Please let me know how to resolve this issue.
Thank you,
Mohan
adder_dut.pdf (19.2 KB)
classes.pdf (49.0 KB)
run_do file.pdf (17.8 KB)
tb_conventional.pdf (20.9 KB)
tb_uvm_based.pdf (18.1 KB)
