Has anyone implemented the logic for monitoring the baud rate of UART? How we can do so ? If the baud rate deviates or the error is greater then 1% between the desired baud rate and achieved baud rate then it should give error.
In reply to jayati3108:
What you are describing is a typical application for SV Assertions. You should model your behavior in this way.
can you please help me with this assertion? How we can write
You can write an inline assertion assertion in baud generator block to check whether the baud_o is generated properly or not, instead of monitoring it using monitor.
In reply to shanthi:
ok , can we write like: -
lets say required baud rate = 100
allowable baud rate = 99,101 (coz 1% error is allowed)
99>=baud rate<=101
something like this
The generation of baud_o depends on the divider latch register(DLR) value & the down counter. Once the value is loaded in DLR, the down counter gets loaded with DLR value & its keep decrementing every clock cycle, when the count becomes zero baud_o will be generated and again the counter will be reloaded back with the DLR value and process will continue.
You can write an assertion for checking the counter & baud_o generation based on above logic.
I think this is from design perspective. I dont have access to baud clock generation logic. I have to write in verification perspective.
