Hello
In my TB setup for RAL . I have created a class object ral_env_cfg which has instance of reg model and set it in test and then get method in env and get in sequence . It doesn’t throw any error in env but in seq it throws an error as shown
xmvlog: *E,TYCMPAT formal and actual do not have assignment compatible data types (expecting datatype compatible with ‘class uvm_pkg::uvm_component’ but found 'class $unit::cdv_cdns
config db
uvm_config_db #(ral_env_cfg)::set(this,“*”,“ral_env_cfg”,ral_cfg);
if(!uvm_config_db#(ral_env_cfg)::get(this,“”,“ral_env_cfg”,ral_cfg))
uvm_fatal("config","cannot get() ral_env_cfg. Have you set it ?") else uvm_info(“CONFIG WORKING”,1,UVM_LOW)
I don’t understand what is causing this error. Should I set it again in env ?
