Is there any way to turn-off constraint. Suppose, i have 100 constraint. out of 100, i want only one specific constraint should be active and rest of the 99 should be inactive. Is there any in-build function to do that?
Thanks in advance!!!
Hi
Yes , you can turn off constraints with
<object_name>.<constraint_name>.constraint_mode(0) ;
Example :
class Packet;
rand bit [3:0] sof;
rand bit [3:0] eop;
rand bit [7:0] data[];
constraint sof_c
sof < 8 ; sof > 2
constraint eop_c
eop < 8 ; eop > 2
endclass : Packet
Program main;
Packet P = new();
initial
P.sof_c.constraint_mode(0) ; //turn off constraint sof_c
P.randomize();
P.sof_c.constraint_mode(1) ; //turn on constraint sof_c
P.randomize();
endprogram
Hope it is clear else refer SV LRM.
Billa
In reply to vikasbilla:
Hi Billa,
If i have to turn off 99 constraints out of 100 constraints, then i have to write “constraint_mode(0)” 99 times. Is there any direct way or in-build function in system verilog to do that??
Thanks!!
There is no built-in mechanism to turn of all but one constraint in a class, unlike the in-line random variable control that would effectively turn rand_mode off for all but one random variable.
You could set up an array of bits to use in an implication constraint
control[0] -> {block_of_constraints};
control[1] -> {block_of_constraints};
And then it would be relatively straightforward to set the control bits any way you want.
Having 100s of unique constraints in a class seems a bit unusual, you may need to explain further what you are trying to accomplish.
Thanks Dave !!!
