Hi
I am trying to debug a monitor class in environment class. Everything seems fine, but I get this error which I haven’t figure out why?
Error-[SE] Syntax error
token ‘acc_monitor’ should be a valid type. Please declare it
virtual if it is an Interface.
“acc_env.sv”, 33: token is ‘;’
acc_monitor input_mon;
this is monitor class:
class acc_monitor;
acc_in_trans tx_in1;
mailbox #(acc_in_trans) mb2;
mailbox #(acc_in_trans) mb3;
virtual ac_if mon_if;
task run();
forever begin
tx_in1=new();
@(posedge mon_if.clk iff !mon_if.rst)
foreach(mon_if.in[i]) tx_in1.in[i]<=mon_if.in[i];
tx_in1.rst<=mon_if.rst;
mb2.put(tx_in1);
mb3.put(tx_in1);
//foreach(tx_in1.in[i])
// $display("in is %0d, sum is %0d, rst is %0d", tx_in1.in[i], tx_in1.sum, tx_in1.rst);
endclass : acc_monitor
