To check clock toggling
What are the different ways to check clock is toggling or not when reset is enabled?
(with and without assertions)
In reply to Kishankk:
This link should give you 2 approaches you can take.
https://verificationacademy.com/forums/systemverilog/assertion-implementation#reply-111758
Ben@systemverilog.us
or Links_to_papers_books - Google Docs
Thank you so much Ben for the assertion approach and your papers and books link.
Much Useful!!!
Can you provide any other ways to check the clock toggling without assertions?
That link
provides a solution without SVA.
Using the same concepts as explained in my previous link
// Modified to your requirements that for now are very vague.
//   If reset==0 then check clock toggling forever. Period of the clk==1/2 T
//   If reset==1 then no toggle
// 1) Using a task that can be called without a timeout
   bit err0, err1; // for debug
   let T= 3; // T is a 1/2 period
   let T1= T+1; //T1, a bit more than T to capture a clk edge
    task automatic t_clk_reset1();
       int count;
       while(reset==1) begin
          #T1; // a bit more than a half period
          //   If reset==1 then no toggle until reset==1
          @(posedge clk) if(reset==1) count=count+1;
           // should not count when reset==1
         join_any
         am_3clk_after_en: assert_final(reset==1 && count==0) else err1=err1+1;
         count=0;
   task automatic t_clk_reset0();
     int count;
     while(reset==0) begin
          //   If reset==0 then check clock toggling .
           @(posedge clk) if(reset==0) count=count+1; // should count
       join_any
       am_3clk_after_en: assert_final(reset==0 && count>0) else err0=err0+1;
       count=0;
    always @(reset)  begin
      t_clk_reset1();
      t_clk_reset0();
DId an update above.
This is untested, but it looks OK now.
Tasks are fired upon a change in reset.
Each task forks 2 processes, one is a fixed delay during which a clk event may occur and may update a count.
Any of the processes, timeout or clocking event, conclude the fork and an immediate assertion check the count.
The while repeats the test until a change in the reset, upon which new tasks are fired.
TB for the solution if clock toggling or not toggling with reset
Note the firing of the tasks with a fork join_none
module m;
  bit reset, clk, tbclk, a=1, ferror;
  int err0, err1; // for debug
  always #4 tbclk = !tbclk; // testbench clock
  always #3 clk = !clk && ferror==0;
  function void f(bit i);
      if(i==1) err1=err1+1;
      else err0=err0+1;
     int count;
          #8; // time to detect a clk posedge
        join_any
        am_3clk_after_en: assert final(reset==0 || count==0) else f(1);
        count=0;
     int count;
        #8; // a bit more than a half period
      join_any
      am_3clk_after_en: assert final(reset==1 || count>0) else f(0);
      count=0;
  always @(reset)  begin // tas firing
      t_clk_reset1();
      t_clk_reset0();
    join_none
    $dumpfile("dump.vcd"); $dumpvars;
    // normal operation
    #1 reset=1; #1;
    reset=0; ferror=0;
    repeat(5)  @(posedge clk);
    reset=1;
    #7 fork repeat(5) begin ferror=1; @(posedge clk); end join_none
    repeat(5) @(posedge tbclk);
    reset=0;
    repeat(9) @(posedge tbclk);
    ferror=0;
    reset=0;     #30 $finish;
