I am considering the best way to start/select sequences in a test class. There are following ways as far as I know. I listed Pros and Cons of each way. Which one do you think the best way? Tell me your opinions, suggestions, ideas and objections, etc.
1. Manual sequence start
1-a : Direct Sequencer Assignment
task Test::run_phase();
seq1.start(env.agent1.seqr);
Directly selects the target sequence.
Pros. : Straightforward, simple and easy to understand
Cons. : Test class needs to know the layer below env.
1-b : Virtual Sequence
v_seq.seqr1_ = env.agent1.seqr;
v_seq.start(null);
task Virtul_Sequence::body()
seq1.start(seqr1_);
Factory override or start different virtual sequences to select target sequences
Pros : No virtual sequencer is created
Cons : Test needs to know layer below env and connect sequencer(s)
Cons : A lot of extra components, virtual sequences, are necessary (Different virtual sequence selection way)
Cons : Difficult to understand for those who doesn't know factory override well. (Factory override way)
1-c : Virtual sequence and Virtual Sequencer
function Env::connect_phase();
v_seqr.seqr1_ = agent1.seqr;
v_seq.start(env.v_seqr);
$cast(v_seqr, m_sequencer);
seq1.start(v_seqr.seqr1_);
Pros : Test doesn't need to know the layer below env.
Cons : Extra component, virtual sequencer, is created
Cons : Need to create multiple virtual sequences per test (Different virtual sequence selection way)
1-d : Sequencer handles in Env (My original way)
seq1.start(env.seqr1_);
Pros : Easy to understand.
Pros : Not need to know layer below Env.
Cons : Not suggested in UVM user guide nor Verification Academy
2. Default Sequence Assignment
function Test::build_phase();
uvm_config_db#(uvm_object_wrapper)::set
( this,
"env.agent1.seqr.run_phase",
"default_sequence",
Sequence1::type_id::get()
Pros : Don't need to create virtual sequences and virtual sequencer
Pros : Well-known way
Cons : Test needs to know the layer below env?
Cons : Difficult to understand for those who doesn't know the concept of default sequence and configuration database
I know Mentor suggests 1-b in Verification Academy while they don’t recommend 1-c. However, I don’t get the drawback of 1-c they insist on. I guess 1-c was suggested by Cadence before.
Personally, I think 1-a or 1-d is a good way because they are clear and easy to understand. I don’t like 2.
The background of my question is that I am preparing a simple UVM example for those who doesn’t know UVM now. I don’t think the current UVM is suggesting definitive test sequence start/selection ways. So, I haven’t decided in which way I should implement. I hope this matter will be clarified in the next version of UVM in the near future.
I am looking forward to anyone’s comments.
