Below is my task from driver for driving Ethernet packet to DUT:
task drive_transfer(packet_pkt); //packet is transaction item
byte unsigned_bytes[];
int pkt_len,i=0,packet_size;
int position_dvaln=1;//Increment until it matches value for driving data valid low
pkt_len = pkt.pack_bytes(bytes); //get Ethernet packet packed in bytes
packet_size = bytes.size(); //get Ethernet packet size
while(i <= packet_size)
if(position_dvaln == (pkt.dvaln_pos))//Deassert data valid for current X'fer
while(pkt.dvaln_cycle!=0)
vif.cb.sig_dval <= 'b0; //keep data valid low for dvaln_cycle clkcycles
@(vif.cb);
pkt.dvaln_cycle --;
vif.cb.sig_dval <= 1'b1;
i=i+4;
position_dvaln++; //keep incr by 1 until it matches value to deassert data valid
Here, once the condition is met for driving data valid low (first in in while loop), it enters the loop for keeping data valid low for x cycles.
But it doesn’t complete the loop and hangs on 2nd loop execution.
On commenting vif.cb.sig_dval <= 'b0; inside while loop it completes test, else it hangs.
Where does packet_size change inside of the while(packet_size) loop? If packet_size never changes, I see no way of exiting the while(packet_size) loop. Is there something missing?
For eg. if pkt.dvaln_pos = 17, then for first 16 X’fer dval <= 'b1 is driven. After that IF condition is triggered, it enters the while loop drives the dval<='b0; but hangs after that waiting for posedge of clk(clocking block).
If I don’t drive dval<=0 in the if condition, ten same logic/loop works well and completes the test.
I am unable to understand how is driving dval<=0 is hanging test?
Can you use blocking assignment instead of non blocking inside the task. Since you are using a task which executes sequentially it is always better to use blocking assignments.
Replace
with
vif.cb.sig_dval = 'b0;
Please include print statements on both the while Loop and post the output here . Now its difficult to comment where actually test is hanging.
Also display i value in print statements
