Is the “Ternary operator” can be used in sequential always block?
The sample code
always @(posedge clk) begin
if(reset) begin
//multiple statements
else begin
r_temp<= a? b : c; //can that be used in here
The sample code
if(reset) begin
else begin
In reply to designMaster:
Operators are usually restricted only by the data types of allowed operands(‘a’ must be an integral type; ‘b’ and ‘c’ should have assignment compatible types). Operands may have restrictions based the location from where they are declared or referenced.
The only operators that have some restrictions based on their location are the ones involving an assignment (++, – +=, etc.)
Will that cause any synthesizing problems or any such issue.
I don’t understand what your concern is. It sounds like you’re having a synthesis issue that’s more than what you’ve explained so far.
