Hi Sir
This is my task in my case:
task automatic get_user_cmd_list_value(string cmd_name, output logic [15:0] cmd_value,output logic [15:0] cmd_address);
for (int i = 0; i < user_cmd_list.size(); i++)
if (user_cmd_list[i].name == cmd_name)
cmd_value = user_cmd_list[i].command;
cmd_address = user_cmd_list[i].address;
$display("Command for name %s; command is %h; address is ", cmd_name, cmd_value,cmd_address);
return;
$error("Command not found for name %s", cmd_name);
But when i want to invoke its at other sv file,i met an error:
if i
logic [15:0] cmd;
logic [15:0] reg_addr;
get_user_cmd_list_value("TEST1",cmd);
Result is correct,i can get cmd value.but if i use this sentence,Xcelium report an error:
get_user_cmd_list_value("TEST1",,reg_addr);
Explicit default argument not declared for corresponding formal argument [SystemVerilog]
I’m curious about this issue. If the parameter cannot be omitted, why is the first case correct? Can you help me with this?
