Task execution based on SV Regions
Hi Forum Moderators,
Figure 4-1 of SV LRM describes all the SV Regions
Note: There is no direct loopback from Reactive to Active.The loopback is from Re-NBA to Active.
I am trying examples that operate on
  • Loopback from Active to Active
  • Loopback from Reactive to Active
module tb;
  bit clk ;
  int c , val = 2;
  always #5 clk = !clk;
  always @(posedge clk) c <= c + 1; // Updated in NBA region
  semaphore sema = new(0);
  task automatic delay( int count );
    if( count > 0 ) begin
      repeat(count) @(posedge clk);
  // For no +define :: What should the value of 'c' be in the next 2 statements ?
    $display("Task completes at T:%0t with c == %0d",$time,c);
    im: assert ( c == 3);
    sema.put(1);
   `ifdef TASK
    @(posedge clk);
    delay(val);
   `else
    assert property( @(posedge clk) (1, delay( val )) );
   `endif
    sema.get(1);
    $finish();
(1) Using +define+TASK ::
  • ‘delay’ gets called in active region at time:5 units.
  • Event control @(posedge clk); would unblock in active region which is an example of loopback from Active to Active region.
  • Immediate assertion would execute in Active region of T:25 using value of ‘c’ as 2
    Hence fail_action block executes ( which is $error by default )
(2) Using no +define ::
  • delay executes in Reactive region as it’s a subroutine called on match of sequence (1)
For (2) I am seeking inputs for the following ::
[Q1] Would the event control @(posedge clk) execute in Active region via loopback from Re-NBA to Active ?
[Q2] In which SV region would the $display() within ‘delay’ execute ?
[Q3] Would the Immediate assertion execute in Reactive region ( using value of ‘c’ as 3 ) ?
[Q4] Should the immediate assertion pass or fail at T:25 ? I observe different results across EDA tools
The loopbacks in figure 4-1 represent loops within the same time-slot. When a process encounters an event control @ or delay #, the process resumes in the same region it got suspended. However, many regions could have been executed in that duration, especially if the resumption happens in another time-slot.
[A1] The @(posedge clk) suspends and executes in the same re-active region regardless of which region the clk updates.
[A2] the reactive region. One a process starts in a region it cannot change which region it executes in.
[A3] same as A2
[A4] I see all tools failing the assertion,
