I have constructed a simple System verlog module and a test-bench for calculating the value of nCr for different combinations of n and r. For this i have connected the DUT and the testbench by constructing a simple modport interface ‘combinter’. The ‘top’ module is also constructed. Below is the actual code for my module, testbench, interface and top module:
interface: int.svh
interface combinter();
logic [6:0] n;
logic [1:0] r;
logic [12:0] C;
modport DUT(input n,r, output C);
modport TEST(output n,r,input C);
endinterface: combinter
module: combin.sv
`timescale 1ns / 1ps
///Verilog module for calculating nCr, where n is a 7 bit//
///integer and r= 0,1,2//
///author: Rohan Pandit//
module combin(combinter.DUT combif);
//input [6:0] n, // inputs n and r//
//input [1:0] r,
//output reg [12:0] C //output C//
always @(combif.n or combif.r) //enter the loop only when n or r changes//
if (combif.n < combif.r)
combif.C = 13'd0;
else if(combif.r == 2'b00 && combif.n >= combif.r) // case 1 : r=0//
combif.C = 13'd1;
else if(combif.r == 2'b01 && combif.n >= combif.r) // case 2: r=1//
combif.C = combif.n;
else if(combif.r == 2'b10 && combif.n >= combif.r) // case 3: r=2//
case(combif.n)
7'd2: combif.C = 13'd1;
7'd3: combif.C = 13'd3;
7'd4: combif.C = 13'd6;
7'd5: combif.C = 13'd10;
7'd6: combif.C = 13'd15;
7'd7: combif.C = 13'd21;
7'd8: combif.C = 13'd28;
7'd9: combif.C = 13'd36;
7'd10: combif.C = 13'd45;
7'd11: combif.C = 13'd55;
7'd12: combif.C = 13'd66;
7'd13: combif.C = 13'd78;
7'd14: combif.C = 13'd91;
7'd15: combif.C = 13'd105;
7'd16: combif.C = 13'd120;
7'd17: combif.C = 13'd136;
7'd18: combif.C = 13'd153;
7'd19: combif.C = 13'd171;
7'd20: combif.C = 13'd190;
7'd21: combif.C = 13'd210;
7'd22: combif.C = 13'd231;
7'd23: combif.C = 13'd253;
7'd24: combif.C = 13'd276;
7'd25: combif.C = 13'd300;
7'd26: combif.C = 13'd325;
7'd27: combif.C = 13'd351;
7'd28: combif.C = 13'd378;
7'd29: combif.C = 13'd406;
7'd30: combif.C = 13'd435;
7'd31: combif.C = 13'd465;
7'd32: combif.C = 13'd496;
7'd33: combif.C = 13'd528;
7'd34: combif.C = 13'd561;
7'd35: combif.C = 13'd595;
7'd36: combif.C = 13'd630;
7'd37: combif.C = 13'd666;
7'd38: combif.C = 13'd703;
7'd39: combif.C = 13'd741;
7'd40: combif.C = 13'd780;
7'd41: combif.C = 13'd820;
7'd42: combif.C = 13'd861;
7'd43: combif.C = 13'd903;
7'd44: combif.C = 13'd946;
7'd45: combif.C = 13'd990;
7'd46: combif.C = 13'd1035;
7'd47: combif.C = 13'd1081;
7'd48: combif.C = 13'd1128;
7'd49: combif.C = 13'd1176;
7'd50: combif.C = 13'd1225;
7'd51: combif.C = 13'd1275;
7'd52: combif.C = 13'd1326;
7'd53: combif.C = 13'd1378;
7'd54: combif.C = 13'd1431;
7'd55: combif.C = 13'd1485;
7'd56: combif.C = 13'd1540;
7'd57: combif.C = 13'd1596;
7'd58: combif.C = 13'd1653;
7'd59: combif.C = 13'd1711;
7'd60: combif.C = 13'd1770;
7'd61: combif.C = 13'd1830;
7'd62: combif.C = 13'd1891;
7'd63: combif.C = 13'd1953;
7'd64: combif.C = 13'd2016;
7'd65: combif.C = 13'd2080;
7'd66: combif.C = 13'd2145;
7'd67: combif.C = 13'd2211;
7'd68: combif.C = 13'd2278;
7'd69: combif.C = 13'd2346;
7'd70: combif.C = 13'd2415;
7'd71: combif.C = 13'd2485;
7'd72: combif.C = 13'd2556;
7'd73: combif.C = 13'd2628;
7'd74: combif.C = 13'd2701;
7'd75: combif.C = 13'd2775;
7'd76: combif.C = 13'd2850;
7'd77: combif.C = 13'd2926;
7'd78: combif.C = 13'd3003;
7'd79: combif.C = 13'd3081;
7'd80: combif.C = 13'd3160;
7'd81: combif.C = 13'd3240;
7'd82: combif.C = 13'd3321;
7'd83: combif.C = 13'd3403;
7'd84: combif.C = 13'd3486;
7'd85: combif.C = 13'd3570;
7'd86: combif.C = 13'd3655;
7'd87: combif.C = 13'd3741;
7'd88: combif.C = 13'd3828;
7'd89: combif.C = 13'd3916;
7'd90: combif.C = 13'd4005;
7'd91: combif.C = 13'd4095;
7'd92: combif.C = 13'd4186;
7'd93: combif.C = 13'd4278;
7'd94: combif.C = 13'd4371;
7'd95: combif.C = 13'd4465;
7'd96: combif.C = 13'd4560;
7'd97: combif.C = 13'd4656;
7'd98: combif.C = 13'd4753;
7'd99: combif.C = 13'd4851;
7'd100: combif.C = 13'd4950;
7'd101: combif.C = 13'd5050;
7'd102: combif.C = 13'd5151;
7'd103: combif.C = 13'd5253;
7'd104: combif.C = 13'd5356;
7'd105: combif.C = 13'd5460;
7'd106: combif.C = 13'd5565;
7'd107: combif.C = 13'd5671;
7'd108: combif.C = 13'd5778;
7'd109: combif.C = 13'd5886;
7'd110: combif.C = 13'd5995;
7'd111: combif.C = 13'd6105;
7'd112: combif.C = 13'd6216;
7'd113: combif.C = 13'd6328;
7'd114: combif.C = 13'd6441;
7'd115: combif.C = 13'd6555;
7'd116: combif.C = 13'd6670;
7'd117: combif.C = 13'd6786;
7'd118: combif.C = 13'd6903;
7'd119: combif.C = 13'd7021;
7'd120: combif.C = 13'd7140;
7'd121: combif.C = 13'd7260;
7'd122: combif.C = 13'd7381;
7'd123: combif.C = 13'd7503;
7'd124: combif.C = 13'd7626;
7'd125: combif.C = 13'd7750;
7'd126: combif.C = 13'd7875;
7'd127: combif.C = 13'd8001;
default: combif.C = 13'dx;
endcase
else if ((combif.n > 127) || (combif.r > 2))
combif.C = 13'bxxxxxxxxxxxxx;
testbench: combin_tb.sv:
module combin_tb (combinter.TEST combif);
int a,b;
bit check;
logic [12:0] C1;
initial
$display("Module combin(): Engineer Rohan Pandit");
check = 0;
combif.r = 2'd0;
combif.n = 7'd0;
/* foreach(n[i])
n[i] = i;
foreach(r[j])
n[j] = j;*/
for (a = 0; a<=2; a = a +1)
combif.n = 7'd0;
for (b = 0; b<=127; b= b+1)
if(combif.r == 2'b00) // case 1: r=0//
C1 = 13'd1;
#2
if( combif.C !== C1)
check = 1;
#2
$display("Fail: n = %d, r = %d, out = %d, expected output = %d", combif.n, combif.r, combif.C, C1);
else if(combif.r == 2'b01) // case 2: r=1//
C1 = combif.n;
#2
check = 1;
#2
else if(combif.r == 2'b10) // case 3: r=2//
C1 = ((combif.n)*((combif.n)-1)) / 2;
#2
check = 1;
#2
combif.n = combif.n + 1 ;
combif.r = combif.r + 1 ;
if(check != 1)
$display("Benchmark passed");
else $display("Benchmark failed");
interface: int.svh
logic [6:0] n;
logic [1:0] r;
logic [12:0] C;
top module: top.sv
combinter combif();
combin u1(combif.DUT);
combin_tb t1(combif.TEST);
The problem is every time i compile the these modules, they compile perfectly, but while simulating it gives the following error every time:
"(vsim-3695) /u0/users/9/rpandit2/DSD2/msim_tut/tb/combin_tb.sv(0): T he interface port ‘combif’ must be passed an actual interface.
Time: 0 ps Iteration: 0 Instance: /combin_tb File: /u0/users/9/rpandit2/D SD2/msim_tut/tb/combin_tb.sv
FATAL ERROR while loading design
Error loading design
I am stuck at this point even after trying all possible solutions and methods. Please do help and suggest some solutions.
