Hi all,
just a quick question regarding my current issue.
The randomization works, but I do not get how I should print out how many people got grades of each range I have set up using constraints.
This is my code for now
module constraint_distrib (
initial
$fsdbDumpfile("dump.fsdb");
$fsdbDumpvars(0, constraint_distrib);
/*-----CLASSES-----*/
class the_tests;
rand bit [7:0] the_grade;
constraint limit_score {the_grade <= 100;}
endclass : the_tests
typedef enum {F, D, C, B, A} grade;
class myGrade extends the_tests;
rand grade grade_type;
int average;
constraint grade_range
(grade_type == F) <-> the_grade inside {[0:59]};
(grade_type == D) <-> the_grade inside {[60:69]};
(grade_type == C) <-> the_grade inside {[70:79]};
(grade_type == B) <-> the_grade inside {[80:89]};
(grade_type == A) <-> the_grade inside {[90:100]};
endclass : myGrade
// beginning stimulus
int Accepted, Below_A, Come_on, Down_bad, Failed;
myGrade students;
students = new;
// among 100 students, show grade distribution among these guys
for (int i = 0; i < 100; i++)
if (students.randomize() == 1)
// $display("Grade: %s", students.grade_type);
$display("Grade num: %0d", students.the_grade);
case (students.the_grade)
F: Failed++;
D: Down_bad++;
C: Come_on++;
B: Below_A++;
A: Accepted++;
endcase
$display("RANDOMIZATION FAILED");
$display("A: %0d B: %0d C: %0d D: %0d F: %0d ", Accepted, Below_A, Come_on, Degenerate, Failed);
$finish;
Unfortunately, when I tried printing out the grade distribution, all I get is the following:
A: 0 B: 2 C: 2 D: 2 F: 1
Is there something that I did not consider or something that I am not understanding well?
Thank you
Sangwoo
