How to write the following property without Non Constant expression error?
property falling_check;
@(posedge clk) $rose(r) |-> ##[d:d+6] ($fell(f));
Below is an assertion that works. Note tha the first_match() is needed because without it, the assertion will never fail.
module varm;
/* property falling_check;
endproperty*/
bit clk, r, f, go=1, reject;
int d=2, count1, count2;
property p_falling_check;
int v1, v2;
@(posedge clk)
($rose(r), v1=d) |-> (first_match((1, v1=v1-1'b1) [*1:$] ##0 (v1==0, v2=6))
// intersect !$fell(f, @(posedge clk)) [*1:$]) ##0 // incorrect
intersect !f [*1:$]) ##0
(first_match((1, v2=v2-1) [*1:$] ##0 v2==0) intersect $fell(f, @(posedge clk)) [=1]) ;
ap_falling_check: assert property(@(posedge clk)p_falling_check);
initial forever #10 clk=!clk;
repeat(200) begin
@(posedge clk);
#2 if (!randomize(r, f) with
{ r dist {1'b1:=1, 1'b0:=8};
f dist {1'b1:=1, 1'b0:=5};})
`uvm_error("MYERR", "This is a randomize error")
$finish;
Thankyou very much Ben, but for
@(posedge clk) $rose(r) ##[d:d+6] !f
the below didn’t work
int v1, v2;
@(posedge clk)
(rose(r), v1=d) |-> (first_match((1, v1=v1-1'b1) [*1:] ##0 (v1==0, v2=6))
// intersect !fell(f, @(posedge clk)) [*1:]) ##0 // incorrect
intersect !f [*1:]) ##0
(first_match((1, v2=v2-1) [*1:] ##0 v2==0) intersect (!f, @(posedge clk)) [=1]) ;
can you please help?
In reply to ranjithkumar d:
The model, repeated below, emulates "$rose(r) ##[d:d+6] !f ". Below are the simulation results
Model checks that between the rose of r and the 1st d (2 in my simulation) there is no f
That is presented in
The model then states that thereafter, there is an occurrence of fell of f up to no more than 6 cycles.
module varm;
endproperty*/
int v1, v2;
@(posedge clk)
repeat(200) begin
@(posedge clk);
$finish;
