SystemVerilog Assertion on $rose
Hi everyone,
Quick question on $rose() function for SVA.
Given a property:
property s_a;
    @(posedge clk) $rose(a) |=> b;
Between two rising edges of the clk signal, if signal ‘a’ starts with 0, then changes to 1 then changes back to 0 before reaching the next rising edge of a clock, would the $rose(a) return True or False?
Best Regards,
Sangwoo
I think that if a rising_edge is formed between two rising edges, it will not run the rose function.
the signal “a” is checked transitions to a value of 1 on every positive edge of the clock. If the transition does not occur, the assertion will fail.
In your case, it will be fail.
SVA samples using clocking event, in this case posedge clk - so at both posedge-s the value of a is 0, hence $rose(a) should be false.
