Can anyone explain to me the following syntax?
array_1={<<{33'h000000023}};
{<<{expression}}
is the SystemVerilog streaming operator which in this case is unpacking the literal 'h23 in reverse order (right LSB to left MSB) into the unpacked array_1 (assuming it is declared as an unpacked array).
Thanks Dave!
Is there a way to concatenate the “expression”. As an example I want to do the following:
bits= 1001010 // These are 7 bits only
array_1 ={<<{33'b {bits}}} // I want 33 bits here with 0 appending after 7 bits. In this case the following number '000000000000000000000000001001010'
I tried the above but got the error:
unexpected character’{’ is illegal in this context.
In reply to debuggerzc:
You could do
array_1 ={<<{26’b0,bits}}};
But if you give me the declaration of array_1, there might be a better way because the streaming operator will 0 fill on the right automatically if the target is has more bits than the source. It would also help to show us the final result you are looking for.
