System Verilog- How to parse string to instantiate class
I am getting a class type and assigning it to a string-
string class_name = r_pkt.get_type_name(); // r_pkt is a class. Name of the class is router_packet.
At this point, string class_name has “router_packet”
Now I want to use this string to parse the class name and instantiate it.
class_name class_h;
basically I want this using class name that I have in string -
router_packet class_h;
How do I achieve it? Is there a system verilog construct that can parse the string and use it as class instantiation?
Please let me know.
In reply to shivamdec:
Generally, there is nothing in SystemVerilog that allows you to convert a string to an identifier. As a compiled language, you cannot form identifiers dynamically at run-time.
However there are schemes to associate strings names with the creation of class objects. The UVM has a mechanism called the “factory” which requires a registration step in the class definition, and then construction with a create_object_by_name() method.
The UVM has an even more efficient factory scheme that avoids the use of string by using a proxy class uvm_object_wrapper and get_type().
